| [MOFScript] Problem with executing MOFScript programmatically [message #385321] |
Tue, 02 September 2008 09:26  |
Originally posted by: Stefan.Warwas.freenet.de
I am developing an Eclipse plug-in that executes a MOFScript
transformation on a selected model to generate source code.
Unfortunately, I have the following problem: The transformation
consists of several m2t files that are imported by the main m2t file. If
I start a new instance of Eclipse to test the plug-in, the
transformation sometimes works and sometimes not (without changing
anything). The transformation always executes the main m2t file, but
(sometimes) the imported m2t files can not be resolved. If I export the
plug-in and copy it to another Eclipse's plugin folder, only the main
m2t file is executed (the imported ones never). The error message is:
#Runtime Error in FunctionCallEvaluator:# Unknown function ...
I followed the MOFScript User Guide 0.6 to execute the transformation
programmatically. I checked the compile path etc. but I could not find
the problem. ParserUtil does not complain about the imports. As far as I
understood I just have to invoke the ParserUtil with the main m2t file,
right? The examples I found considered only one m2t file without imports.
Perhaps somebody can give me some hints how to solve this problem. Thanks!
Stefan
| Re: [MOFScript] Problem with executing MOFScript programmatically [message #385359 is a reply to message #385321] |
Wed, 10 September 2008 09:11   |
I think the problem is caused by a wrong compile path. How do I have to
set the compile-path of ParserUtil when I want to load a transformation
that is stored inside a plug-in? Somehow ParserUtil can not resolve the
imports if I determine the compile path with the FileLocator inside the
plug-in. For example:
C:\eclipse\configuration\org.eclipse.osgi\bundles\586\1\.cp\ transformations\jademm2java
If I pass a static path like C:\transformations\jademm2java it works.
Stefan
Stefan Warwas schrieb:
> Hello,
> Stefan
| Re: [MOFScript] Problem with executing MOFScript programmatically [message #621769 is a reply to message #385321] |
Stefan
> Hello,
> Stefan
| Re: [MOFScript] Problem with executing MOFScript programmatically [message #633720 is a reply to message #621769] |
Tue, 19 October 2010 02:24  |
Adrian Noguero Messages: 18 Registered: July 2009 |
Junior Member |
Dear Stefan,
Indeed you need to set-up correctly the compile path as you suggested in your previous message.
In order to locate files stored inside a Plugin you have to make sure that those files are included in the plug-in bundle, by including them in the build tab of your plugin.
Then you can access files in plugins using the FileLocator class in Eclipse.
I hope this helps!
Adrian
FUDForum. Page generated in 0.01664 seconds
