Home » Eclipse Projects » Rich Client Platform (RCP) » Table tree Implementation.
Table tree Implementation. [message #633311] Sat, 16 October 2010 04:19 Go to next message
ash is currently offline ash
Can any one tell how to implement Table tree ....
Tabletree class is deprecated in 3.3 eclipse wht is the alternative for this..
How to implement ?
i want table tree structuire in this format
+ Node one
----------------------- Node 1 rec1
----------------------- Node 1 rec 2
+ node two
----------------------- Node 2 rec 1
----------------------- Node 2 rec 2
n
Can any tell how to implement this code snippet is appreciated
can be implemnted with treeviewer and tableviewer?
if s how ?
Ashok
Re: Table tree Implementation. [message #633603 is a reply to message #633311] Mon, 18 October 2010 10:19 Go to previous messageGo to next message
Grant Gayed is currently offline Grant Gayed
At the SWT level you use Tree and TreeColumns, for an example see
http://dev.eclipse.org/viewcvs/index.cgi/%7Echeckout%7E/org. eclipse.swt.snippets/src/org/eclipse/swt/snippets/Snippet170 .java .
It looks like the following snippet demonstrates using tree columns in
TreeViewers:
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.jface.s nippets/Eclipse%20JFace%20Snippets/org/eclipse/jface/snippet s/viewers/Snippet055HideShowColumn.java?view=markup .
Grant
<ashok_kumar_rr@yahoo.com> wrote in message
news:i9bmvi$ngt$1@news.eclipse.org...
> Hi
> this..
> How to implement ?
> + Node one ----------------------- Node 1 rec1
> + node two ----------------------- Node 2 rec 1
> ----------------------- Node 2 rec 2 .
> n
> if s how ?
> Thanks
> Ashok
Re: Table tree Implementation. [message #633647 is a reply to message #633311] Mon, 18 October 2010 12:39 Go to previous messageGo to next message
Thanks BOSS......!
Re: Table tree Implementation. [message #633666 is a reply to message #633647] Mon, 18 October 2010 14:53 Go to previous message
Federico Gaule is currently offline Federico Gaule
Take a look at http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/reference/api/org/eclipse/jface/viewers/Tr eeViewerColumn.html
Thats what you need.
Previous Topic:suggestion for a perspective navigation panel
Next Topic:Product export: org.eclipse.emf.edit.ui not found
Current Time: Wed May 22 10:32:28 EDT 2013
Powered by FUDForum. Page generated in 0.03930 seconds
