Home » Modeling » Epsilon » switch-case null issue
switch-case null issue [message #633645] Mon, 18 October 2010 12:36 Go to next message
Henning is currently offline Henning
Member
I encountered a strange behavior inside a switch-case statement. It comes down to this.
rule exampleTrafo
	transform d : Source!Domain
	to d : Target!Domain{
	var choice = "bigDecision";
	switch(choice){
		case "bigDecision" :
			var temp = createSomething();
			if(not temp.isDefined())
				"ohh boy".println();
operation createSomething() : Target!Element1{
	var returnValue = new Target!Element1;
	if(returnValue.isDefined())
		"I'm ready to go".println();
	return returnValue;
I would expect to get a plain "I'm ready to go" , unfortunately I get the following output:
Buildfile: /Users/henning/Documents/workspaces/diplom/my.example/launch .xml
loadModels:
main:
[epsilon.etl - exampleTrafo.etl] I'm ready to go
[epsilon.etl - exampleTrafo.etl] ohh boy
BUILD SUCCESSFUL
Total time: 246 milliseconds
Is this behavior intended?
Henning
Re: switch-case null issue [message #633665 is a reply to message #633645] Mon, 18 October 2010 14:12 Go to previous message
Dimitrios Kolovos is currently offline Dimitrios Kolovos
Hi Henning,
Thanks for reporting this! You've uncovered another bug it seems! I've
located the problem and will fix it shortly. In the meantime, when you
perform an assignment within a case "x" please use := instead of =
e.g. var temp := createSomething();
Dimitris
On 18/10/2010 17:36, Henning wrote:
> comes down to this.
> rule exampleTrafo
> switch(choice){
> case "bigDecision" : var temp = createSomething();
> return returnValue;
> .xml
> loadModels:
> main:
> BUILD SUCCESSFUL
> Best regards,
> Henning
Previous Topic:onefile="true" doesn't seem to work
Next Topic:Automatic validation.
Current Time: Thu May 23 06:25:42 EDT 2013
Powered by FUDForum. Page generated in 0.01691 seconds
