Home » Eclipse Projects » Rich Client Platform (RCP) » suggestion for a perspective navigation panel(can an application have a component present in all the perspectcives?)
suggestion for a perspective navigation panel [message #633616] Mon, 18 October 2010 10:51 Go to next message
Luca Ferrari is currently offline Luca Ferrari
Hi all,
I've got my rcp application with several perspectives that can be chosen thru a perspective switcher at the top of the application itself using a toolbar. I'd like to change it using collapsiblebuttons placing the button panel on the bottom-left side, like in Outlook. I know how to place the buttons into a viewpart, but since I need them to switch over perspectives, I need to make them a kind of "fast view perspective independent" and always present in the application. Is there a way to achieve this?
Re: suggestion for a perspective navigation panel [message #633654 is a reply to message #633616] Mon, 18 October 2010 13:18 Go to previous message
Paul Webster is currently offline Paul Webster
You can contribute your own ControlContribution to the trim areas using
the constants defined in MenuUtil and org.eclipse.ui.menus/menuContribution
PW
Paul Webster
http://wiki.eclipse.org/Platform_Expression_Framework
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Previous Topic:How to fix "Perspective <mypersp> has been made into a local copy" ?
Next Topic:Table tree Implementation.
Current Time: Wed May 22 04:19:24 EDT 2013
Powered by FUDForum. Page generated in 0.01481 seconds
