Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Simple SWT Table(Header size, center a cell)
Simple SWT Table [message #633050] Fri, 15 October 2010 04:25 Go to next message
Andrea  is currently offline Andrea
I'm a new user of SWT. I have a problem:
I have edited a simple snippets file
package swtsnippets;
import org.eclipse.swt.SWT;
import org.eclipse.swt.custom.TableEditor;
import org.eclipse.swt.graphics.Image;
import org.eclipse.swt.layout.GridData;
import org.eclipse.swt.layout.GridLayout;
import org.eclipse.swt.widgets.Button;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.swt.widgets.Table;
import org.eclipse.swt.widgets.TableColumn;
import org.eclipse.swt.widgets.TableItem;
public class ParkedTable {
	static Image image;
		Display display = new Display();
		Shell shell = new Shell(display);
		shell.setLayout(new GridLayout());
		Table table = new Table(shell, SWT.MULTI | SWT.BORDER
				| SWT.FULL_SELECTION);
		GridData data = new GridData(SWT.FILL, SWT.FILL, true, true);
		data.heightHint = 200;
		table.setLayoutData(data);
		table.setLinesVisible(true);
		table.setHeaderVisible(true);
		image = new Image(display, "C:\\antenna.png");
		createColumns(table);
		setData(table);
		resizeColumns(table);
		shell.pack ();
		shell.open ();
		while (!shell.isDisposed ()) {
			if (!display.readAndDispatch ()) display.sleep ();
		display.dispose ();
	private static void resizeColumns(Table table) {
		for (int i=1; i<4; i++) {
			table.getColumn (i).pack ();
			table.getColumn(2).setAlignment(SWT.CENTER);
			System.out.println(table.getHeaderHeight());
	private static void setData(Table table) {
		for (int i=0; i<12; i++) {
			TableItem item = new TableItem (table, SWT.NONE);
			item.setText (0, "0x0000");
			item.setText (1, "0x466467-0x466ef7");
			Button b = new Button(table, SWT.CHECK | SWT.CENTER);
			TableEditor editor = new TableEditor (table);
			editor.grabHorizontal = editor.grabVertical = true;
			editor.setEditor (b, item, 2);
			b = new Button(table, SWT.CHECK | SWT.RESIZE);
			editor.setEditor (b, item, 3);
	private static void createColumns(Table table) {
		// Create five columns
	      TableColumn column = new TableColumn(table, SWT.CENTER);
	      column.setImage(image);
	      column.setWidth(50);
	      column.setText("MAC Address");
	      column.setText("Parked");
	      column.setText("Active");
There are tree problems:
I want set the header size from 24 to 30 px
I want center checkbox button in cells...
I want change background color of some cells
Thanks.
Andrea
[Updated on: Fri, 15 October 2010 05:17]
Report message to a moderator
Re: Simple SWT Table [message #633497 is a reply to message #633050] Mon, 18 October 2010 04:45 Go to previous messageGo to next message
If i'm not been clear... reply me..
Re: Simple SWT Table [message #633561 is a reply to message #633050] Mon, 18 October 2010 08:21 Go to previous messageGo to next message
Lakshmi Shanmugam
1) There is no method currently to set the header size.
2) You can place the buttons in the center of the cell using
editor.horizontalAlignment = SWT.CENTER; and editor.grabHorizontal = false. Also set editor.minimumWidth.
Please see this snippet for an example --> Snippet126
3) You can the change the background of the table cells using Custom drawing. Please see Snippet229. Also helpful --> Article on custom drawing
Lakshmi P Shanmugam
Re: Simple SWT Table [message #633602 is a reply to message #633561] Mon, 18 October 2010 10:24 Go to previous message
Ok thanks a lot. Very usefull response
Previous Topic:Table with scrollbar
Next Topic:SWT Browser Scrollbar
Current Time: Sat May 18 22:46:24 EDT 2013
Powered by FUDForum. Page generated in 0.04544 seconds
