| Table with scrollbar [message #632757] |
Thu, 14 October 2010 03:44  |
Andrea Pierangeli Messages: 1 Registered: October 2010 |
Junior Member |
Hi everybody, i'm having trouble with scrollbars in table.
The problem is that my table is very large (more than 1000 rows) and i want the user to be able to scroll it. owever every solution i tried did not work. My question is: how can i get the following code to work and to display scrollbars?
Thanks in advance
import org.eclipse.swt.SWT;
import org.eclipse.swt.widgets.Button;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Group;
import org.eclipse.swt.widgets.Menu;
import org.eclipse.swt.widgets.MenuItem;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.swt.widgets.TabFolder;
import org.eclipse.swt.widgets.TabItem;
import org.eclipse.swt.widgets.Table;
import org.eclipse.swt.widgets.TableColumn;
import org.eclipse.swt.widgets.TableItem;
import org.eclipse.swt.widgets.Text;
import org.eclipse.swt.layout.FillLayout;
import org.eclipse.swt.layout.GridData;
import org.eclipse.swt.layout.GridLayout;
import org.eclipse.swt.layout.RowLayout;
public class SchedaClienteShell {
private String user=null; // @jve:decl-index=0:
private Shell shell=null; // @jve:decl-index=0:visual-constraint="10,-44"
private Display display=null;
private Composite datiCliente=null;
private TabFolder clienteTabFolder=null;
private Composite appuntamentiEffettuatiTab = null;
private Composite appuntamentiProgrammatiTab = null;
private Composite comunicazioniTab = null;;
private Table appuntamentiEffettuatiTable=null;
private Table appuntamentiProgrammatiTable;
private Table comunicazioniTable;
public void initialize(String user){
this.user=user;
display = new Display();
shell = new Shell(display);
shell.setText("Scheda cliente");
shell.setMaximized(true);
shell.setLayout(new RowLayout(SWT.HORIZONTAL));
this.initializePannelloDatiCliente();
this.initializeTabs();
shell.open();
while (!shell.isDisposed()) {
if (!display.readAndDispatch()) {
display.sleep();
//Sezione tabs
private void initializeTabs() {
clienteTabFolder=new TabFolder(shell,SWT.NONE);
clienteTabFolder.setLayout(new GridLayout());
//clienteTabFolder.setLayoutData(new RowData(SWT.FILL,SWT.NONE));
createAppuntamentiEffettuatiTab();
createAppuntamentiProgrammatiTab();
createComunicazioniTab();
createGruppoTab();
createAgenteTab();
TabItem tabItem = new TabItem(clienteTabFolder, SWT.NONE);
tabItem.setControl(appuntamentiEffettuatiTab);
tabItem.setText("Appuntamenti effettuati");
TabItem tabItem1 = new TabItem(clienteTabFolder, SWT.NONE);
tabItem1.setControl(appuntamentiProgrammatiTab);
tabItem1.setText("Appuntamenti programmati");
TabItem tabItem2 = new TabItem(clienteTabFolder, SWT.NONE);
tabItem2.setText("Appuntamenti programmati");
tabItem2.setControl(comunicazioniTab);
tabItem2.setText("Comunicazioni");
TabItem tabItem3 = new TabItem(clienteTabFolder, SWT.NONE);
clienteTabFolder.pack();
private void createAppuntamentiEffettuatiTab() {
appuntamentiEffettuatiTab = new Composite(clienteTabFolder, SWT.NONE);
appuntamentiEffettuatiTab.setLayout(new GridLayout());
appuntamentiEffettuatiTable = new Table(appuntamentiEffettuatiTab, SWT.MULTI | SWT.CHECK | SWT.FULL_SELECTION | SWT.BORDER);
appuntamentiEffettuatiTable.setLayoutData(new GridData(SWT.NONE, SWT.FILL, true, true));
appuntamentiEffettuatiTable.setHeaderVisible(true);
appuntamentiEffettuatiTable.setLinesVisible(true);
TableColumn[] colonne = new TableColumn[8];
colonne[0]=new TableColumn(appuntamentiEffettuatiTable, SWT.NONE);
colonne[0].setText("Data");
colonne[1]=new TableColumn(appuntamentiEffettuatiTable, SWT.NONE);
colonne[1].setText("Ora");
colonne[2]=new TableColumn(appuntamentiEffettuatiTable, SWT.NONE);
colonne[2].setText("Durata");
colonne[3]=new TableColumn(appuntamentiEffettuatiTable, SWT.NONE);
colonne[3].setText("Indirizzo");
colonne[4]=new TableColumn(appuntamentiEffettuatiTable, SWT.NONE);
colonne[4].setText("Agente di riferimento");
colonne[5]=new TableColumn(appuntamentiEffettuatiTable, SWT.NONE);
colonne[5].setText("Agente incaricato");
colonne[6]=new TableColumn(appuntamentiEffettuatiTable, SWT.NONE);
colonne[6].setText("Descrizione");
colonne[7]=new TableColumn(appuntamentiEffettuatiTable, SWT.NONE);
colonne[7].setText("Motivo");
fillTable(appuntamentiEffettuatiTable);
private void fillTable(Table table){
table.setRedraw(false);
//Riempire con i dati pescati dal DB
for (int i=0; i<100; i++){
TableItem item=new TableItem(table,SWT.NONE);
for (int j=0; j<table.getColumnCount(); j++){
item.setText(j, "item "+i);
table.getColumns()[j].pack();
table.setRedraw(true);
private void createAppuntamentiProgrammatiTab() {
appuntamentiProgrammatiTab = new Composite(clienteTabFolder, SWT.NONE);
appuntamentiProgrammatiTab.setLayout(new GridLayout());
appuntamentiProgrammatiTable = new Table(appuntamentiProgrammatiTab, SWT.MULTI | SWT.CHECK | SWT.FULL_SELECTION | SWT.BORDER);
appuntamentiProgrammatiTable.setLayoutData(new GridData(SWT.NONE, SWT.FILL, true, true));
appuntamentiProgrammatiTable.setHeaderVisible(true);
appuntamentiProgrammatiTable.setLinesVisible(true);
TableColumn[] colonne = new TableColumn[7];
colonne[0]=new TableColumn(appuntamentiProgrammatiTable, SWT.NONE);
colonne[1]=new TableColumn(appuntamentiProgrammatiTable, SWT.NONE);
colonne[2]=new TableColumn(appuntamentiProgrammatiTable, SWT.NONE);
colonne[2].setText("Termine ultimo");
colonne[3]=new TableColumn(appuntamentiProgrammatiTable, SWT.NONE);
colonne[4]=new TableColumn(appuntamentiProgrammatiTable, SWT.NONE);
colonne[5]=new TableColumn(appuntamentiProgrammatiTable, SWT.NONE);
colonne[5].setText("Motivo");
colonne[6]=new TableColumn(appuntamentiProgrammatiTable, SWT.NONE);
colonne[6].setText("Stato");
fillTable(appuntamentiProgrammatiTable);
//Other tabs similar to the first one
//Sezione pannello Dati Cliente
private void initializePannelloDatiCliente() {
if(datiCliente==null){
datiCliente=new DatiClienteComposite(shell, SWT.NONE);
[Updated on: Thu, 14 October 2010 16:50] Report message to a moderator
| Re: Table with scrollbar [message #633572 is a reply to message #632757] |
Mon, 18 October 2010 08:53  |
Lakshmi Shanmugam Messages: 271 Registered: July 2009 Location: India |
It looks like this is happening due to RowLayout. Can you use either FillLayout or GridLayout on the shell instead of RowLayout, the scrollbar appears as expected.
Lakshmi P Shanmugam
FUDForum. Page generated in 0.01503 seconds
