Home » Modeling » AMP » [SOLVED] Couldn't generate chart
[SOLVED] Couldn't generate chart [message #631952] Sun, 10 October 2010 21:04 Go to next message
Oliver Mannion is currently offline Oliver Mannion
Member
When running edu.brook.manual.model1.CoordinationGame I would get
org.eclipse.amp.agf.chart Couldn't generate chart
org.eclipse.birt.chart.exception.ChartException
at org.eclipse.birt.chart.factory.Generator.build(Generator.java:1076)
at org.eclipse.birt.chart.factory.Generator.build(Generator.java:856)
at org.eclipse.amp.agf.chart.ChartEditPart.regenerateChart(ChartEditPart.java:395)
at org.eclipse.amp.agf.chart.ChartEditPart$5.run(ChartEditPart.java:337)
at org.eclipse.amp.agf.chart.ChartEditPart.refresh(ChartEditPart.java:339)
at org.eclipse.amp.agf.chart.ChartEditPart$ChartModelListener.update(ChartEditPart.java:190)
at org.eclipse.amp.axf.view.SWTAsyncModelListener.doUpdate(SWTAsyncModelListener.java:137)
at org.eclipse.amp.axf.view.SWTAsyncModelListener.access$1(SWTAsyncModelListener.java:134)
at org.eclipse.amp.axf.view.SWTAsyncModelListener$ReportingRunner.run(SWTAsyncModelListener.java:48)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:134)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4041)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3660)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2629)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2593)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2427)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:670)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:663)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:115)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:619)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
Caused by: java.lang.NullPointerException
at org.eclipse.birt.chart.render.BaseRenderer.instances(BaseRenderer.java:2186)
at org.eclipse.birt.chart.factory.Generator.build(Generator.java:1060)
... 32 more
11/10/2010 11:36:49 AM org.eclipse.birt.chart.util.PluginSettings getRenderer
SEVERE: (ECLIPSE-ENV) Could not find series renderer impl for org.eclipse.birt.chart.model.type.impl.LineSeriesImpl
So I went to Install New Software, selected http://download.eclipse.org/amp/updates/releases
and checked
AMP AGF Chart
AMP AGF Zest
This solved the problem!
Re: [SOLVED] Couldn't generate chart [message #633289 is a reply to message #631952] Fri, 15 October 2010 22:31 Go to previous messageGo to next message
Miles Parker is currently offline Miles Parker
Oliver Mannion wrote on Sun, 10 October 2010 21:04
and checked
AMP AGF Chart
AMP AGF Zest
Oliver how did you install AMP originally before it worked? Curious because this should work OOTB. Did you just check some of the entries for AMP on the original install?
Re: [SOLVED] Couldn't generate chart [message #633431 is a reply to message #633289] Sun, 17 October 2010 16:20 Go to previous message
Member
I think somehow my installation got a bit out of wack after I downloaded the AMP sources.
I've since tried a fresh install OOTB and everything worked fine as expected.
Previous Topic:What replaces the Swing Navigator in AMP/Escape?
Next Topic:Could not read class: ede.brook.model.CoordinationGame. Please ensure that the class exists in class
Current Time: Tue May 28 07:47:26 EDT 2013
Powered by FUDForum. Page generated in 0.03425 seconds
