Home » Eclipse Projects » Web Tools Project (WTP) » Command used to stop tomcat
Command used to stop tomcat [message #633073] Fri, 15 October 2010 05:38 Go to next message
Richard Evans is currently offline Richard Evans
Is it possible to configure the command used to stop tomcat?
It seems to use the start launch configuration by default. This causes problems if the JRE has been configured to listen on certain ports (for JMX, SNMP, etc) because the stop command then fails to listen and does not get a chance to execute the stop.
Re: Command used to stop tomcat [message #633127 is a reply to message #633073] Fri, 15 October 2010 09:10 Go to previous messageGo to next message
Larry Isaacs is currently offline Larry Isaacs
Unfortunately, what is available is
https://bugs.eclipse.org/bugs/show_bug.cgi?id=153680 At the moment, a
number of "com.sun.management.jmxremote" system arguments are removed
for the stop command, so JMX shouldn't be a problem. It is simple to
add additional system properties to remove. Less simple is implementing
separate start and stop VM arguments.
Larry
Re: Command used to stop tomcat [message #633132 is a reply to message #633073] Fri, 15 October 2010 09:19 Go to previous messageGo to next message
Removing the properties would work fine for me. Are the stripped properties hardcoded or is there some configuration somewhere I can update?
Richard
Re: Command used to stop tomcat [message #633215 is a reply to message #633132] Fri, 15 October 2010 12:37 Go to previous message
> Richard
They are currently hardcoded.
Larry
Previous Topic:Helios JSDT bug?
Next Topic:Nested lib folder structure at deployment on JBoss AS 5.1 in server view
Current Time: Fri May 24 00:19:38 EDT 2013
Powered by FUDForum. Page generated in 0.06736 seconds
