Home » Eclipse Projects » Standard Widget Toolkit (SWT) » SWT Browser does not navigate links
SWT Browser does not navigate links [message #632532] Wed, 13 October 2010 06:41 Go to next message
Nirmal Sasidharan
I have created a SWT browser component and set the contents using setText() method. The HTML content has some anchors which point to some locations within the document. For example,
<a href="#ModelArchitecture">Model Architecture</a>
<h1 id="ModelArchitecture">Model Architecture</h1>
When I click on the link, instead of navigating, it displays a blank page with contents as
blank#ModelArchitecture
However, the navigation works if I save the same contents to a file and set the content using setUrl().
Also the above problem occurs only on Windows (XP, SP3, IE6). The navigation works perfectly file on OSX Safari.
What could be the problem?
Nirmal
Re: SWT Browser does not navigate links [message #632884 is a reply to message #632532] Thu, 14 October 2010 10:43 Go to previous message
Grant Gayed is currently offline Grant Gayed
This looks like a bug, I've logged
https://bugs.eclipse.org/bugs/show_bug.cgi?id=327786 .
Grant
"Nirmal Sasidharan" <nirmalts@yahoo.com> wrote in message
news:i9426r$bhk$1@news.eclipse.org...
> Hello,
> with contents as
> Nirmal
Previous Topic:JDK 7 on Windows: No aero styled widgets
Next Topic:Table with scrollbar
Current Time: Sat May 18 10:05:09 EDT 2013
Powered by FUDForum. Page generated in 0.02196 seconds
