Home » Eclipse Projects » Buckminster » SVN Client Exception
SVN Client Exception [message #632648] Wed, 13 October 2010 13:23 Go to next message
Wim Jongman is currently offline Wim Jongman
Hi Folks,
I am running a build on hudson and run into svn problems.
Has anybody seen this before? Does the SVN client come from the target environment or is it baked into the buckminster hudson plugin?
I do a cspex import and everything seems to be resolving fine until I reach this error.
ERROR [0002] : org.tigris.subversion.svnclientadapter.SVNClientException: org.tigris.subversion.javahl.ClientException: svn: Can't close file '/tmp/report.tmp': No such path or directory.
ERROR: org.tigris.subversion.svnclientadapter.SVNClientException: org.tigris.subversion.javahl.ClientException: svn: Can't close file '/tmp/report.tmp': No such path or directory.
Thanks for helping,
Wim
Re: SVN Client Exception [message #632681 is a reply to message #632648] Wed, 13 October 2010 17:20 Go to previous message
I finally removed the complete project from the repository and checked it in again. That solved it.
Wim
Previous Topic:Setting API baseline for workspace
Next Topic:Two branding issues resolved...
Current Time: Sat May 25 00:36:20 EDT 2013
Powered by FUDForum. Page generated in 0.04864 seconds
