Home » Eclipse Projects » EclipseLink » JPQL query does not locate the constructor correctly
JPQL query does not locate the constructor correctly [message #632566] Wed, 13 October 2010 09:19 Go to next message
Pavel Zelenka is currently offline Pavel Zelenka
Member
I have problem with this query:
select new cz.mediaservis.metro.entity.SedmickaRemitendaObce(v.vykladka .obec, max(v.vykladka.cislo)) from Vykaz v ...
It always ends up with exception: java.lang.NoSuchMethodException: cz.mediaservis.metro.entity.SedmickaRemitendaObce.<init>(java.lang.String, java.lang.Object)
I use EclipseLink 1.1.1.v20090430-r4097
Any ideas what's wrong?
Re: JPQL query does not locate the constructor correctly [message #632654 is a reply to message #632566] Wed, 13 October 2010 13:41 Go to previous message
Chris Delahunt is currently offline Chris Delahunt
The exception is occuring because SedmickaRemitendaObce does not have a constructor that takes a String and Object as a paramter. Feel free to file a bug so that Max uses the type defined for the v.vykladka.cislo and vote for it to get it fixed. The mean time is to use Object in the constructor as the argument type.
Best Regards,
Chris
Previous Topic:Strange behavior in loading entities
Next Topic:em.remove throws exception: identifier is too long
Current Time: Sun May 19 05:10:19 EDT 2013
Powered by FUDForum. Page generated in 0.02476 seconds
