Home » Modeling » EMF » Bidirectional reference(Bidirectional reference tables problem)
Bidirectional reference [message #632269] Tue, 12 October 2010 07:36 Go to next message
MaK is currently offline MaK
I have a following problem:
1. object A has reference (0 ... *) to object B,
2. reference B has set eopposite attribute to A,
3. object B has reference (0 ... *) to object A,
4. reference A has set eopposite attribute to B.
So, it is bidirectional reference. A problem is that there are created two independent tables connecting A with B :
1. A -> AB -> B
2. B -> BA -> A
I need one table e.g. AB to be able to set/get one list of objects in two places. Could you indicate me solution of this problem?
MaK
Re: Bidirectional reference [message #632278 is a reply to message #632269] Tue, 12 October 2010 08:12 Go to previous messageGo to next message
Ed Merks is currently offline Ed Merks
MaK,
Comments below.
MaK wrote:
> Hello,
It would be more clear if you gave these references names; after all,
the opposite is a feature not a class.
So there are two different bidirectional references between A and B or
just one.
> 1. A -> AB -> B
> 2. B -> BA -> A
Tables? This is a question about Teneo?
> MaK
Re: Bidirectional reference [message #632299 is a reply to message #632278] Tue, 12 October 2010 09:45 Go to previous messageGo to next message
Ed Merks wrote on Tue, 12 October 2010 08:12
MaK,
Comments below.
MaK wrote:
> Hello,
just one.
> 1. A -> AB -> B
> 2. B -> BA -> A
It's about CDO.
> MaK
[CDO] Bidirectional reference [message #632320 is a reply to message #632299] Tue, 12 October 2010 10:26 Go to previous messageGo to next message
MaK,
Please prefix questions about CDO with [CDO]
>> MaK,
>> Comments below.
>> MaK wrote:
>> > Hello,
>> or just one.
>> created > two independent tables connecting A with B :
>> > 1. A -> AB -> B
>> > 2. B -> BA -> A
>> It's about CDO.
>> in > two places. Could you indicate me solution of this problem?
>> > MaK
Re: [CDO] Bidirectional reference [message #632343 is a reply to message #632269] Tue, 12 October 2010 11:24 Go to previous messageGo to next message
Eike Stepper is currently offline Eike Stepper
Hi Mak,
I suspect that you're using the DBStore of CDO? While it is theoretically possible with this store to customize the IMappingStrategy, the IClassMappings, etc, I doubt that many people have tried that so far. The particular kind of mapping you seem to require is not possible with the DBStore as it is shipped. Maybe Stefan wants to add something?
I guess that the HibernateStore is more likely to support complex mapping types. Martin?
Cheers
/Eike
http://www.esc-net.de
Am 12.10.2010 13:36, schrieb MaK:
> Hello,
> 2. reference B has set eopposite attribute to A, 3. object B has reference (0 ... *) to object A,
> 1. A -> AB -> B
> 2. B -> BA -> A
> MaK
Re: [CDO] Bidirectional reference [message #632415 is a reply to message #632343] Tue, 12 October 2010 15:54 Go to previous message
Martin Taal is currently offline Martin Taal
The HibernateStore allows you to override the default mapping in detail,
including specifying join tables etc. There are some specifics however
for n:m associations which need to be indexed (set vs. list semantics),
see here for details:
http://wiki.eclipse.org/Teneo/Hibernate/ModelRelational/Asso ciation_Mapping
For more info on the hibernatestore and its mapping capabilities see here:
http://wiki.eclipse.org/CDO_Hibernate_Store_Model_Relational _Mapping
For general info on the HibernateStore see here:
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
On 10/12/2010 05:24 PM, Eike Stepper wrote:
> Hi Mak,
> Cheers
> /Eike
> http://thegordian.blogspot.com
> http://twitter.com/eikestepper
>> Hello,
>> 1. A -> AB -> B
>> 2. B -> BA -> A
>> MaK
The Netherlands
Previous Topic:inheritance from own defined EDataType
Next Topic:[CDO] Timeout when connecting to server
Current Time: Sat May 25 04:25:30 EDT 2013
Powered by FUDForum. Page generated in 0.01665 seconds
