Home » Eclipse Projects » Nebula » Multiple Columns in Row Header
Multiple Columns in Row Header [message #632217] Tue, 12 October 2010 03:26 Go to next message
Roel De Nijs is currently offline Roel De Nijs
I can create a GridTableViewer with a custom label for the row header.
But what I actually need for our application is: instead of just 1 column as row header I need the first 2 or 3 columns to be the row header (and stay at the start of the line when scrolling).
Is it possible with the current API? Or is there some alternative? Maybe creating a custom row header renderer will do the job, but based on the source that seems a bit tricky.
Re: Multiple Columns in Row Header [message #632260 is a reply to message #632217] Tue, 12 October 2010 07:03 Go to previous message
I found KTable as a possible alternative which allows to use more than 1 column as row header.
Previous Topic:XViewer examples and API?
Next Topic:Gantt Chart - select events connections
Current Time: Thu May 23 19:12:18 EDT 2013
Powered by FUDForum. Page generated in 0.09460 seconds
