Home » Eclipse Projects » BIRT » java.lang.UnsupportedOperationException: setSpecification is not supported.
java.lang.UnsupportedOperationException: setSpecification is not supported. [message #631504] Thu, 07 October 2010 14:49 Go to next message
Dave Missing name is currently offline Dave Missing name
Override database connection on server side:
task.getAppContext().put("OdaJDBCDriverPassInConnection", connection);
I got the following exception:
at org.eclipse.birt.report.data.oda.jdbc.Statement.setSpecifica tion(Statement.java:943)
at org.eclipse.datatools.connectivity.oda.consumer.helper.OdaQu ery.setSpecification(OdaQuery.java:1488)
at org.eclipse.birt.data.engine.odaconsumer.Connection.setOdaQu erySpec(Connection.java:318)
at org.eclipse.birt.data.engine.odaconsumer.Connection.prepareO daQuery(Connection.java:288)
at org.eclipse.birt.data.engine.odaconsumer.Connection.prepareS tatement(Connection.java:197)
at org.eclipse.birt.data.engine.executor.DataSource.prepareStat ement(DataSource.java:300)
at org.eclipse.birt.data.engine.executor.DataSourceQuery.prepar e(DataSourceQuery.java:276)
at org.eclipse.birt.data.engine.impl.PreparedOdaDSQuery$OdaDSQu eryExecutor.prepareOdiQuery(PreparedOdaDSQuery.java:441)
at org.eclipse.birt.data.engine.impl.QueryExecutor.prepareExecu tion(QueryExecutor.java:340)
at org.eclipse.birt.data.engine.impl.PreparedQuery.doPrepare(Pr eparedQuery.java:448)
at org.eclipse.birt.data.engine.impl.PreparedDataSourceQuery.pr oduceQueryResults(PreparedDataSourceQuery.java:190)
at org.eclipse.birt.data.engine.impl.PreparedDataSourceQuery.ex ecute(PreparedDataSourceQuery.java:178)
at org.eclipse.birt.data.engine.impl.PreparedOdaDSQuery.execute (PreparedOdaDSQuery.java:145)
at org.eclipse.birt.report.data.adapter.impl.DataRequestSession Impl.execute(DataRequestSessionImpl.java:617)
at org.eclipse.birt.report.engine.data.dte.DteDataEngine.doExec uteQuery(DteDataEngine.java:152)
at org.eclipse.birt.report.engine.data.dte.AbstractDataEngine.e xecute(AbstractDataEngine.java:265)
at org.eclipse.birt.report.engine.executor.ExtendedGenerateExec utor.executeQueries(ExtendedGenerateExecutor.java:205)
at org.eclipse.birt.report.engine.executor.ExtendedGenerateExec utor.execute(ExtendedGenerateExecutor.java:65)
at org.eclipse.birt.report.engine.executor.ExtendedItemExecutor .execute(ExtendedItemExecutor.java:62)
at org.eclipse.birt.report.engine.internal.executor.dup.Suppres sDuplicateItemExecutor.execute(SuppressDuplicateItemExecutor .java:43)
at org.eclipse.birt.report.engine.internal.executor.wrap.Wrappe dReportItemExecutor.execute(WrappedReportItemExecutor.java:4 6)
at org.eclipse.birt.report.engine.internal.executor.l18n.Locali zedReportItemExecutor.execute(LocalizedReportItemExecutor.ja va:34)
at org.eclipse.birt.report.engine.layout.html.HTMLBlockStacking LM.layoutNodes(HTMLBlockStackingLM.java:65)
at org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout (HTMLPageLM.java:90)
at org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutE ngine.layout(HTMLReportLayoutEngine.java:99)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doR un(RunAndRenderTask.java:180)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run (RunAndRenderTask.java:77)
BIRT 2.6.1
Thanks for help.
Dave
Re: java.lang.UnsupportedOperationException: setSpecification is not supported. [message #631524 is a reply to message #631504] Thu, 07 October 2010 16:20 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason Weathersby
Dave,
I believe this is a nuisance error and the DTP dev team is aware of it.
The report should still run fine. Did it work for you.
Jason
> BIRT 2.6.1
> Thanks for help.
> Dave
Jason Weathersby
BIRT Exchange
Re: java.lang.UnsupportedOperationException: setSpecification is not supported. [message #631556 is a reply to message #631524] Thu, 07 October 2010 19:00 Go to previous messageGo to next message
Linda Chan
Like Jason said, this is simply a trace logging message. Minor correction though: DTP has actually nothing to do with the message nor the exception.
The exception thrown by the ODA JDBC driver is simply caught and logged by BIRT data engine. In BIRT 2.6.1, the FINE level logging message even got refined to explicitly said that it is benign. Something like:
"Ignoring the UnsupportedOperationException thrown by ODA driver (<data source type>) on IQuery#setSpecification. This call is optional and does not affect query processing."
Re: java.lang.UnsupportedOperationException: setSpecification is not supported. [message #631564 is a reply to message #631504] Thu, 07 October 2010 21:39 Go to previous messageGo to next message
I looked at the image directory. The chart image was not created.
In eclipse design, I removed all report parameters related to jdbc connection(url, username,password), and set the connection at runtime.
How should I debug the issue?
Dave
Re: java.lang.UnsupportedOperationException: setSpecification is not supported. [message #631749 is a reply to message #631564] Fri, 08 October 2010 11:26 Go to previous messageGo to next message
Dave,
Does it work when you do not set the connection in the appcontext?
Jason
> Thanks
> Dave
Jason Weathersby
BIRT Exchange
Re: java.lang.UnsupportedOperationException: setSpecification is not supported. [message #631887 is a reply to message #631749] Sat, 09 October 2010 23:07 Go to previous messageGo to next message
Jason,
It is working now. It might be due to a report design error. After recreating the design, it worked fine.
I set log LEVEL to warn, FINE/DEBUG level messages was logged.
EngineConfig config = new EngineConfig( );
config.setLogConfig(logDir, Level.WARNING);
engine.changeLogLevel(Level.WARNING);
Is there a way to config the logging? limit log file size and file number.
Dave
Re: java.lang.UnsupportedOperationException: setSpecification is not supported. [message #632150 is a reply to message #631887] Mon, 11 October 2010 14:32 Go to previous message
Have you looked at
EngineConfig.setLogRollingSize
and
EngineConfig.setLogMaxBackupIndex
Jason
On 10/9/2010 11:08 PM, Dave wrote:
> Jason,
> Dave
Jason Weathersby
BIRT Exchange
Previous Topic:Report parameters in url
Next Topic:Printing report
Current Time: Sun May 19 03:50:55 EDT 2013
Powered by FUDForum. Page generated in 0.02047 seconds
