Home » Eclipse Projects » Web Tools Project (WTP) » Eclipse Helios WASCE v2.1 Integration
Eclipse Helios WASCE v2.1 Integration [message #632022] Mon, 11 October 2010 04:56 Go to next message
Ozan Ozgur is currently offline Ozan Ozgur
Greetings,
I have Helios installed and would like to have my webapp's work at websphere and i want to do it though eclipse.
I have installed WASCE v2.1 and the eclipse adaptor plugin. I defined the server in the servers section, I can stop start the server and launch to administrator console, but when I try to run my project in this server, in the "Edit launch configuration properties" window, "Server" tab, there are no servers listed in the "Server:" fied. How can I make my server being listed there?
Thanks a lot in advance.
Ozan.
Re: Eclipse Helios WASCE v2.1 Integration [message #632070 is a reply to message #632022] Mon, 11 October 2010 09:00 Go to previous message
figured it out...the project was imported from a very old version of eclipse (v2.0), and this does not appear to be a dynamic web project when imported to helios. And when adding resources to the server, only these kind of projects appear. Somehow I need to make helios to understand that this is a web project instead of a java project.
Ozan.
Previous Topic:Linked resources
Next Topic:HTML autoformatting - is it configurable?
Current Time: Sat May 25 14:55:46 EDT 2013
Powered by FUDForum. Page generated in 0.01482 seconds
