| Eclipse Helios WASCE v2.1 Integration [message #632022] |
Mon, 11 October 2010 04:56  |
Ozan Ozgur Messages: 4 Registered: August 2010 |
Junior Member |
Greetings,
I have Helios installed and would like to have my webapp's work at websphere and i want to do it though eclipse.
I have installed WASCE v2.1 and the eclipse adaptor plugin. I defined the server in the servers section, I can stop start the server and launch to administrator console, but when I try to run my project in this server, in the "Edit launch configuration properties" window, "Server" tab, there are no servers listed in the "Server:" fied. How can I make my server being listed there?
Thanks a lot in advance.
Ozan.
| Re: Eclipse Helios WASCE v2.1 Integration [message #632070 is a reply to message #632022] |
Mon, 11 October 2010 09:00  |
Junior Member |
figured it out...the project was imported from a very old version of eclipse (v2.0), and this does not appear to be a dynamic web project when imported to helios. And when adding resources to the server, only these kind of projects appear. Somehow I need to make helios to understand that this is a web project instead of a java project.
Ozan.
FUDForum. Page generated in 0.01516 seconds
