Home » Eclipse Projects » EclipseLink » OneToOne mapping on same table
OneToOne mapping on same table [message #631443] Thu, 07 October 2010 10:47 Go to next message
Matti Hansson is currently offline Matti Hansson
Member
Hi!
I have an object model with a Unit having a one-to-one relation to a UnitIdentifier. In the database, all fields of both classes are contained within a single table.
It's easy enough to simply map those classes like usual and call it a day, but this will result in two queries to the database: select the fields of Unit in the correct row, and then select the fields of UnitIdentifier in the same row.
This is fine, I guess, but it makes me hurt a bit inside Razz
Is there a way to do this using a single fetch?
Thanks!
/Matti
Re: OneToOne mapping on same table [message #631699 is a reply to message #631443] Fri, 08 October 2010 09:59 Go to previous messageGo to next message
Chris Delahunt is currently offline Chris Delahunt
EclipseLink has a @JoinFetch annotation you can used on a relationship, or you can use fetch join in JPQL for particular relationships. What is the table and entity setup for these two classes? Do they share a row, are they using inheritance, etc?
Best Regards,
Chris
Re: OneToOne mapping on same table [message #632019 is a reply to message #631443] Mon, 11 October 2010 04:49 Go to previous message
Member
Thanks for the reply, Chris, but @JoinFetch was not quite what I was after. However, I found that @Embeddable/@Embedded does exactly what I want.
Problem solved.
/Matti
Previous Topic:EclipseLink 2.1.1 / Problem with @ManyToOne(fetch = FetchType.LAZY)
Next Topic:Secondary table with join on constant value
Current Time: Fri May 24 09:44:04 EDT 2013
Powered by FUDForum. Page generated in 0.03162 seconds
