Home » Eclipse Projects » BIRT » Resizing problem(Resizing problem)
| Resizing problem [message #631772] |
Fri, 08 October 2010 13:00  |
No real name Messages: 23 Registered: August 2010 |
Junior Member |
I have added my chart to a canvas which is on an SWT composite. I am facing the problem that my chart is not resizing when I resize the window.Could you pls suggest how this can be done?
| Re: Resizing problem [message #631803 is a reply to message #631772] |
Fri, 08 October 2010 15:44  |
Jason Weathersby Messages: 9167 Registered: July 2009 |
What does your paintControl method look like. Take a look at this
example from the source.
Jason
package org.eclipse.birt.chart.examples.api.viewer;
import org.eclipse.birt.chart.api.ChartEngine;
import org.eclipse.birt.chart.device.IDeviceRenderer;
import org.eclipse.birt.chart.device.IUpdateNotifier;
import org.eclipse.birt.chart.examples.api.script.JavaScriptViewer;
import org.eclipse.birt.chart.exception.ChartException;
import org.eclipse.birt.chart.factory.GeneratedChartState;
import org.eclipse.birt.chart.factory.Generator;
import org.eclipse.birt.chart.log.ILogger;
import org.eclipse.birt.chart.log.Logger;
import org.eclipse.birt.chart.model.Chart;
import org.eclipse.birt.chart.model.ChartWithAxes;
import org.eclipse.birt.chart.model.ChartWithoutAxes;
import org.eclipse.birt.chart.model.attribute.AxisType;
import org.eclipse.birt.chart.model.attribute.Bounds;
import org.eclipse.birt.chart.model.attribute.ChartDimension;
import org.eclipse.birt.chart.model.attribute.impl.BoundsImpl;
import
org.eclipse.birt.chart.model.attribute.impl.JavaNumberFormat SpecifierImpl;
import org.eclipse.birt.chart.model.component.Axis;
import org.eclipse.birt.core.exception.BirtException;
import org.eclipse.birt.core.framework.PlatformConfig;
import org.eclipse.swt.SWT;
import org.eclipse.swt.events.ControlEvent;
import org.eclipse.swt.events.ControlListener;
import org.eclipse.swt.events.PaintEvent;
import org.eclipse.swt.events.PaintListener;
import org.eclipse.swt.events.SelectionEvent;
import org.eclipse.swt.events.SelectionListener;
import org.eclipse.swt.graphics.Device;
import org.eclipse.swt.graphics.Font;
import org.eclipse.swt.graphics.FontMetrics;
import org.eclipse.swt.graphics.GC;
import org.eclipse.swt.graphics.Image;
import org.eclipse.swt.graphics.Point;
import org.eclipse.swt.graphics.Rectangle;
import org.eclipse.swt.layout.GridData;
import org.eclipse.swt.layout.GridLayout;
import org.eclipse.swt.layout.RowLayout;
import org.eclipse.swt.widgets.Button;
import org.eclipse.swt.widgets.Combo;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Label;
import org.eclipse.swt.widgets.Shell;
* The selector of charts in SWT.
public final class SwtChartViewerSelector extends Composite
implements
PaintListener,
SelectionListener,
IUpdateNotifier
private IDeviceRenderer idr = null;
private Chart cm = null;
private static Combo cbType = null;
private static Combo cbDimension = null;
private static Button btn = null;
private GeneratedChartState gcs = null;
private boolean bNeedsGeneration = true;
private static Button cbPercent = null;
private static Button cbLogarithmic = null;
private static Button cbTransposed = null;
private static ILogger logger = Logger.getLogger(
JavaScriptViewer.class.getName( ) );
* main() method for constructing the selector layout.
* @param args
public static void main( String[] args )
Display display = Display.getDefault( );
Shell shell = new Shell( display );
shell.setSize( 800, 600 );
shell.setLayout( new GridLayout( ) );
SwtChartViewerSelector scv = new SwtChartViewerSelector( shell,
SWT.NO_BACKGROUND );
scv.setLayoutData( new GridData( GridData.FILL_BOTH ) );
scv.addPaintListener( scv );
Composite cBottom = new Composite( shell, SWT.NONE );
cBottom.setLayoutData( new GridData( GridData.FILL_HORIZONTAL ) );
cBottom.setLayout( new RowLayout( ) );
Label la = new Label( cBottom, SWT.NONE );
la.setText( "Choose: " );//$NON-NLS-1$
cbType = new Combo( cBottom, SWT.DROP_DOWN | SWT.READ_ONLY );
String[] models = PrimitiveCharts.getAvailableModelList( );
for ( int i = 0; i < models.length; i++ )
cbType.add( models[i] );
cbType.select( 0 );
cbDimension = new Combo( cBottom, SWT.DROP_DOWN | SWT.READ_ONLY );
cbDimension.add( "2D" );//$NON-NLS-1$
cbDimension.add( "2D with Depth" );//$NON-NLS-1$
cbDimension.select( 0 );
cbTransposed = new Button( cBottom, SWT.CHECK );
cbTransposed.setText( "Transposed" );//$NON-NLS-1$
cbPercent = new Button( cBottom, SWT.CHECK );
cbPercent.setText( "Percent" );//$NON-NLS-1$
cbLogarithmic = new Button( cBottom, SWT.CHECK );
cbLogarithmic.setText( "Logarithmic" );//$NON-NLS-1$
btn = new Button( cBottom, SWT.NONE );
btn.setText( "Update" );//$NON-NLS-1$
btn.addSelectionListener( scv );
shell.setText( scv.getClass( ).getName( ) + " [device=" //$NON-NLS-1$
+ scv.idr.getClass( ).getName( ) + "]" );//$NON-NLS-1$
shell.open( );
while ( !shell.isDisposed( ) )
if ( !display.readAndDispatch( ) )
display.sleep( );
display.dispose( );
* Get the connection with SWT device to render the graphics.
SwtChartViewerSelector( Composite parent, int style )
super( parent, style );
try
PlatformConfig config = new PlatformConfig( );
config.setProperty( "STANDALONE", "true" ); //$NON-NLS-1$ //$NON-NLS-2$
idr = ChartEngine.instance( config ).getRenderer( "dv.SWT"
);//$NON-NLS-1$
catch ( ChartException ex )
logger.log( ex );
addControlListener( new ControlListener( ) {
public void controlMoved( ControlEvent e )
public void controlResized( ControlEvent e )
cm = PrimitiveCharts.createBarChart( );
* (non-Javadoc)
* @see
org.eclipse.swt.events.PaintListener#paintControl(org.eclips e.swt.events.PaintEvent)
public final void paintControl( PaintEvent e )
Rectangle d = this.getClientArea( );
Image imgChart = new Image( this.getDisplay( ), d );
GC gcImage = new GC( imgChart );
idr.setProperty( IDeviceRenderer.GRAPHICS_CONTEXT, gcImage );
idr.setProperty( IDeviceRenderer.UPDATE_NOTIFIER, this );
Bounds bo = BoundsImpl.create( 0, 0, d.width, d.height );
bo.scale( 72d / idr.getDisplayServer( ).getDpiResolution( ) );
Generator gr = Generator.instance( );
if ( bNeedsGeneration )
bNeedsGeneration = false;
try
gcs = gr.build( idr.getDisplayServer( ),
cm,
bo,
null,
null,
null );
catch ( ChartException ce )
ce.printStackTrace( );
try
gr.render( idr, gcs );
GC gc = e.gc;
gc.drawImage( imgChart, d.x, d.y );
catch ( ChartException gex )
showException( e.gc, gex );
* (non-Javadoc)
* @see
org.eclipse.swt.events.SelectionListener#widgetSelected(org. eclipse.swt.events.SelectionEvent)
public void widgetSelected( SelectionEvent e )
if ( e.widget.equals( btn ) )
int iSelection = cbType.getSelectionIndex( );
cm = PrimitiveCharts.createChart( iSelection );
if ( cm instanceof ChartWithAxes )
cbTransposed.setEnabled( true );
cbLogarithmic.setEnabled( true );
cbPercent.setEnabled( true );
ChartWithAxes cwa = ( (ChartWithAxes) cm );
cwa.setTransposed( cbTransposed.getSelection( ) );
Axis ax = cwa.getPrimaryOrthogonalAxis( cwa.getPrimaryBaseAxes( )[0] );
if ( cbLogarithmic.getSelection( ) )
if ( ax.getType( ) == AxisType.LINEAR_LITERAL )
ax.setType( AxisType.LOGARITHMIC_LITERAL );
else
if ( ax.getType( ) == AxisType.LOGARITHMIC_LITERAL )
ax.setType( AxisType.LINEAR_LITERAL );
if ( cbPercent.getSelection( ) == true )
ax.setFormatSpecifier( JavaNumberFormatSpecifierImpl.create( "0'%'"
) );//$NON-NLS-1$
else
ax.setFormatSpecifier( null );
else if ( cm instanceof ChartWithoutAxes )
cbTransposed.setEnabled( false );
cbLogarithmic.setEnabled( false );
cbPercent.setEnabled( false );
if ( cbType.getSelectionIndex( ) == 7
|| cbType.getSelectionIndex( ) == 6
|| cbType.getSelectionIndex( ) == 9 )
cm.setDimension( ChartDimension.TWO_DIMENSIONAL_LITERAL );
else
switch ( cbDimension.getSelectionIndex( ) )
case 0 :
break;
case 1 :
cm.setDimension( ChartDimension.TWO_DIMENSIONAL_WITH_DEPTH_LITERAL );
break;
this.redraw( );
* (non-Javadoc)
* @see
org.eclipse.swt.events.SelectionListener#widgetDefaultSelect ed(org.eclipse.swt.events.SelectionEvent)
public void widgetDefaultSelected( SelectionEvent e )
// TODO Auto-generated method stub
private final void showException( GC g2d, Exception ex )
String sWrappedException = ex.getClass( ).getName( );
Throwable th = ex;
while ( ex.getCause( ) != null )
ex = (Exception) ex.getCause( );
String sException = ex.getClass( ).getName( );
if ( sWrappedException.equals( sException ) )
sWrappedException = null;
String sMessage = null;
if ( th instanceof BirtException )
sMessage = ( (BirtException) th ).getLocalizedMessage( );
else
sMessage = ex.getMessage( );
if ( sMessage == null )
sMessage = "<null>";//$NON-NLS-1$
StackTraceElement[] stea = ex.getStackTrace( );
Point d = this.getSize( );
Device dv = Display.getCurrent( );
Font fo = new Font( dv, "Courier", SWT.BOLD, 16 );//$NON-NLS-1$
g2d.setFont( fo );
FontMetrics fm = g2d.getFontMetrics( );
g2d.setBackground( dv.getSystemColor( SWT.COLOR_WHITE ) );
g2d.fillRectangle( 20, 20, d.x - 40, d.y - 40 );
g2d.setForeground( dv.getSystemColor( SWT.COLOR_BLACK ) );
g2d.drawRectangle( 20, 20, d.x - 40, d.y - 40 );
g2d.setClipping( 20, 20, d.x - 40, d.y - 40 );
int x = 25, y = 20 + fm.getHeight( );
g2d.drawString( "Exception:", x, y );//$NON-NLS-1$
x += g2d.textExtent( "Exception:" ).x + 5;//$NON-NLS-1$
g2d.setForeground( dv.getSystemColor( SWT.COLOR_RED ) );
g2d.drawString( sException, x, y );
x = 25;
y += fm.getHeight( );
if ( sWrappedException != null )
g2d.drawString( "Wrapped In:", x, y );//$NON-NLS-1$
x += g2d.textExtent( "Wrapped In:" ).x + 5;//$NON-NLS-1$
g2d.drawString( sWrappedException, x, y );
x = 25;
y += 10;
g2d.drawString( "Message:", x, y );//$NON-NLS-1$
x += g2d.textExtent( "Message:" ).x + 5;//$NON-NLS-1$
g2d.setForeground( dv.getSystemColor( SWT.COLOR_BLUE ) );
g2d.drawString( sMessage, x, y );
x = 25;
y += 10;
g2d.drawString( "Trace:", x, y );//$NON-NLS-1$
x = 40;
g2d.setForeground( dv.getSystemColor( SWT.COLOR_DARK_GREEN ) );
for ( int i = 0; i < stea.length; i++ )
g2d.drawString( stea[i].getClassName( ) + ":"//$NON-NLS-1$
+ stea[i].getMethodName( ) + "(...):"//$NON-NLS-1$
+ stea[i].getLineNumber( ), x, y );
x = 40;
fo.dispose( );
* (non-Javadoc)
* @see org.eclipse.birt.chart.device.IUpdateNotifier#getDesignTimeM odel()
public Chart getDesignTimeModel( )
return cm;
* (non-Javadoc)
* @see org.eclipse.birt.chart.device.IUpdateNotifier#getRunTimeMode l()
public Chart getRunTimeModel( )
return gcs.getChartModel( );
* (non-Javadoc)
* @see org.eclipse.birt.chart.device.IUpdateNotifier#peerInstance()
public Object peerInstance( )
return this;
* (non-Javadoc)
* @see org.eclipse.birt.chart.device.IUpdateNotifier#regenerateChar t()
public void regenerateChart( )
redraw( );
* (non-Javadoc)
* @see org.eclipse.birt.chart.device.IUpdateNotifier#repaintChart()
public void repaintChart( )
redraw( );
> Thanks
Jason Weathersby
BIRT Exchange
Current Time: Thu May 23 23:28:42 EDT 2013
Powered by FUDForum. Page generated in 0.01532 seconds
