Home » Archived » Tycho » Downloading Tycho / Maven
Downloading Tycho / Maven [message #628725] Thu, 23 September 2010 15:05 Go to next message
Gunnar Wagenknecht is currently offline Gunnar Wagenknecht
where do I download Maven? I'm a bit confused. Downloads are on Apache,
which seems outdated. Issue tracking happens at CodeHaus and Tycho is at
Eclipse.
Any tips?
-Gunnar
Gunnar Wagenknecht
gunnar@wagenknecht.org
http://wagenknecht.org/
Re: Downloading Tycho / Maven [message #628816 is a reply to message #628725] Fri, 24 September 2010 04:54 Go to previous messageGo to next message
Jan Sievers is currently offline Jan Sievers
Hi Gunnar,
The download link on http://eclipse.org/tycho/download.php works.
You need maven 3 beta 1 although beta 3 is already out because we don't
follow each maven beta/RC immediately as there are significant changes to
adapt to.
This will be less confusing once maven 3 is final soon.
As with any other maven plugin, tycho plugins are downloaded by maven as
soon as you start referencing them in your POM.
Tycho is published on the default maven repo
http://repo1.maven.org/maven2/org/sonatype/tycho/ which ensures that all you
need to download is maven 3 and you are good to go, no need to configure
additional maven repos.
Regarding the issue tracker, I had already asked Jason van Zyl, this was his
statement:
"We have a lot of stuff in JIRA so this will just take some time to migrate.
This can happen over the course of the parallel IP process"
Hope this helps,
Jan
"Gunnar Wagenknecht" <gunnar@wagenknecht.org> wrote in message
news:i7g893$htm$1@news.eclipse.org...
> Eclipse.
> Any tips?
> -Gunnar
> Gunnar Wagenknecht
Re: Downloading Tycho / Maven [message #629047 is a reply to message #628816] Sun, 26 September 2010 14:46 Go to previous messageGo to next message
Hi Jan,
Am 24.09.2010 10:54, schrieb Jan Sievers:
I figured that there would be some automatic. But my issue was more
about how to obtain the official Maven download. The version promoted at
Apache was "beta 3". But I wasn't sure if that is the official source.
-Gunnar
Gunnar Wagenknecht
Re: Downloading Tycho / Maven [message #631776 is a reply to message #629047] Fri, 08 October 2010 13:20 Go to previous message
Werner Keil is currently offline Werner Keil
Since today the "beta" should be gone ;-)
Previous Topic:Compiler Integration
Next Topic:IllegalAccessErrors Running JUnit Tests During Build
Current Time: Sat May 18 11:18:05 EDT 2013
Powered by FUDForum. Page generated in 0.01643 seconds
