Good day,
Im just starting to use BIRT after using Eclipse technolegies like RAP its getting use to this system. Up 2 now it all worked as I expected. I have been using Intergrating and Extending BIRT book as a guide. And it worked like a charm.
Now only one thing seems to be failing when I try my tests.
I created a repport with some variables:
<parameters>
<scalar-parameter name="REPORT_ID" id="419" extends="SMARTAPPS.NL.REPORT_ID"/>
<scalar-parameter name="DATABASE_NAME" id="420" extends="SMARTAPPS.NL.DATABASE_NAME"/>
<scalar-parameter name="REPORT_NAME" id="421" extends="SMARTAPPS.NL.REPORT_NAME"/>
<scalar-parameter name="ADVISEUR_ID" id="422" extends="SMARTAPPS.NLT.ADVISEUR_ID"/>
<scalar-parameter name="DATUM_START" id="423" extends="SMARTAPPS.NL.DATUM_START"/>
<scalar-parameter name="DATUM_EIND" id="424" extends="SMARTAPPS.NL.DATUM_EIND"/>
</parameters>
Now I wanted to test how the handlers work so I created a simpel Handler:
import java.util.Date;
import org.eclipse.birt.report.engine.api.script.IReportContext;
import org.eclipse.birt.report.engine.api.script.element.IReportDesign;
import org.eclipse.birt.report.engine.api.script.eventadapter.ReportEventAdapter;
import org.eclipse.birt.report.model.api.ReportDesignHandle;
import org.eclipse.birt.report.model.api.activity.SemanticException;
* @author Martijn Cremer
* Test of a Report Event handler (for smartapps Algemeen)
public class ReportEventHandler extends ReportEventAdapter {
public void beforeFactory(IReportDesign report, IReportContext reportContext) {
@SuppressWarnings("deprecation")
final Date date = new Date(2001, 01, 01);
if ((Date) reportContext.getPageVariable("DATUM_START") == date) {
final ReportDesignHandle rdh = (ReportDesignHandle) reportContext.getReportRunnable().getDesignHandle();
try {
rdh.findElement("VOORBLAD_REPPORT_ID").drop();
} catch (final SemanticException e) {
e.printStackTrace();
Now when I run it in Eclipse BIRT and BIRT Designer Professional i get the following error when I run my report:
Description Resource Path Location Type
org.eclipse.birt.report.engine.api.EngineException: Class nl.smartapps.algemeen.handler.ReportEventHandler not found.
at org.eclipse.birt.report.engine.executor.EventHandlerManager. getInstance(EventHandlerManager.java:81)
at org.eclipse.birt.report.engine.executor.EventHandlerManager. getInstance(EventHandlerManager.java:49)
at org.eclipse.birt.report.engine.script.internal.ScriptExecuto r.getInstance(ScriptExecutor.java:104)
at org.eclipse.birt.report.engine.script.internal.ReportScriptE xecutor.handleAfterFactory(ReportScriptExecutor.java:103)
at org.eclipse.birt.report.engine.api.impl.EngineTask.closeFact ory(EngineTask.java:1771)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doR un(RunAndRenderTask.java:186)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run (RunAndRenderTask.java:77)
at org.eclipse.birt.report.service.ReportEngineService.runAndRe nderReport(ReportEngineService.java:920)
at org.eclipse.birt.report.service.BirtViewerReportService.runA ndRenderReport(BirtViewerReportService.java:973)
at org.eclipse.birt.report.service.actionhandler.BirtGetPageAll ActionHandler.__execute(BirtGetPageAllActionHandler.java:131 )
at org.eclipse.birt.report.service.actionhandler.AbstractBaseAc tionHandler.execute(AbstractBaseActionHandler.java:90)
at org.eclipse.birt.report.soapengine.processor.AbstractBaseDoc umentProcessor.__executeAction(AbstractBaseDocumentProcessor .java:47)
at org.eclipse.birt.report.soapengine.processor.AbstractBaseCom ponentProcessor.executeAction(AbstractBaseComponentProcessor .java:143)
at org.eclipse.birt.report.soapengine.processor.BirtDocumentPro cessor.handleGetPageAll(BirtDocumentProcessor.java:183)
at org.eclipse.birt.report.soapengine.processor.AbstractBaseCom ponentProcessor.process(AbstractBaseComponentProcessor.java: 112)
at org.eclipse.birt.report.soapengine.endpoint.BirtSoapBindingI mpl.getUpdatedObjects(BirtSoapBindingImpl.java:66)
at org.apache.axis.providers.java.RPCProvider.invokeMethod(RPCP rovider.java:397)
at org.apache.axis.providers.java.RPCProvider.processMessage(RP CProvider.java:186)
at org.apache.axis.providers.java.JavaProvider.invoke(JavaProvi der.java:323)
at org.apache.axis.strategies.InvocationStrategy.visit(Invocati onStrategy.java:32)
at org.apache.axis.SimpleChain.doVisiting(SimpleChain.java:118)
at org.apache.axis.SimpleChain.invoke(SimpleChain.java:83)
at org.apache.axis.handlers.soap.SOAPService.invoke(SOAPService .java:454)
at org.apache.axis.server.AxisServer.invoke(AxisServer.java:281 )
at org.apache.axis.transport.http.AxisServlet.doPost(AxisServle t.java:699)
at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherSer vlet.doPost(BirtSoapMessageDispatcherServlet.java:265)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
at org.apache.axis.transport.http.AxisServletBase.service(AxisS ervletBase.java:327)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherSer vlet.service(BirtSoapMessageDispatcherServlet.java:122)
at org.eclipse.equinox.http.registry.internal.ServletManager$Se rvletWrapper.service(ServletManager.java:180)
at org.eclipse.equinox.http.servlet.internal.ServletRegistratio n.service(ServletRegistration.java:61)
at org.eclipse.equinox.http.servlet.internal.ProxyServlet.proce ssAlias(ProxyServlet.java:126)
at org.eclipse.equinox.http.servlet.internal.ProxyServlet.servi ce(ProxyServlet.java:60)
at org.eclipse.equinox.http.jetty.internal.HttpServerManager$In ternalHttpServiceServlet.service(HttpServerManager.java:318)
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder .java:511)
at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandl er.java:390)
at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandl er.java:182)
at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandl er.java:765)
at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapp er.java:152)
at org.mortbay.jetty.Server.handle(Server.java:326)
at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnectio n.java:542)
at org.mortbay.jetty.HttpConnection$RequestHandler.content(Http Connection.java:939)
at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:756)
at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java: 212)
at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java: 404)
at org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEn dPoint.java:409)
at org.mortbay.thread.QueuedThreadPool$PoolThread.run(QueuedThr eadPool.java:582)
Caused by: java.lang.ClassNotFoundException: nl.smartapps.algemeen.handler.ReportEventHandler
at org.eclipse.birt.core.framework.URLClassLoader.findClass1(UR LClassLoader.java:185)
at org.eclipse.birt.core.framework.URLClassLoader$1.run(URLClas sLoader.java:154)
at org.eclipse.birt.core.framework.URLClassLoader$1.run(URLClas sLoader.java:1)
at org.eclipse.birt.core.framework.URLClassLoader.findClass(URL ClassLoader.java:149)
at org.eclipse.birt.report.engine.executor.ApplicationClassLoad er.loadClass(ApplicationClassLoader.java:79)
at org.eclipse.birt.report.engine.executor.EventHandlerManager. getInstance(EventHandlerManager.java:76)
... 56 more
smartappsAlgemeen.rptdesign /smartappsBIRT Algemeen line 2 BIRT Viewer Problem
What am I doing wrong?
I put the Java project containing the handler in the same workbench. As all the documentation i found and read told me. I'm probably missing somting very simple.
[Updated on: Fri, 08 October 2010 10:45]
Report message to a moderator
