Home » Eclipse Projects » BIRT » Using RE API without birt installed on the server machine
Using RE API without birt installed on the server machine [message #631566] Thu, 07 October 2010 21:54
No real name is currently offline No real name
I try to embed the birt report to one existing J2ee web application by using Report Engine API.
We are not allowed to install birt on the server machine.
Is that OK?
1. I create the rptdesign files from my local computer which has eclipse birt installed.
2. put created rptdesign files, RE API jar, jdbc driver jar files and few configuration files
under one directory of the server machine.
3. add jar files (or put jar files in the application under web-inf/lib folder) and configuration files on the classpath
by modifying the batch file of the application server like web logic sever.
If I can not, what is the reason?
Thanks.
Previous Topic:Dynamic where clause in report?
Next Topic:Subreport with XML data source
Current Time: Tue Jun 18 02:38:11 EDT 2013
Powered by FUDForum. Page generated in 0.01584 seconds
