| split() in a computed column preview different from displayed in report [message #630314] |
Fri, 01 October 2010 10:57  |
Chris Chubb Messages: 11 Registered: July 2009 |
Junior Member |
I have a report with a number of computed columns, mostly the results of
splitting a single data field into many report fields. For example
Field3Test:
aField3 = row["Field3"].split("|");
aField3.join("*"); /*This is just to demonstrate the bug. Usually I return aField3[0] or something. */
The contents of Field3 are:
XSV||Mercedes-Benz|300M-V6|2006|WDBRF52H66A82XX|1741098|S560 590497XX|~XSV||Jeep|Wrangle|1997|1J4FY29P7PP23XX|6613725|S56 0590497XX|
When I "Preview Results" in the Data Source Editor the output for Field3Test is:
XSV**Mercedes-Benz*300M-V6*2006*WDBRF52H66A82XX*1741098*S560 590497XX*~XSV**Jeep*Wrangle*1997*1J4FY29P7PP23XX*6613725*S56 0590497XX*
That's as expected. But, when I do a "Preview" on the report (or run it on the server), the output for Field3Test is:
*X*S*V*|*|*M*e*r*c*e*d*e*s*-*B*e*n*z*|*3*0*0*M*-*V*6*|*2*0*0 *6*|*W*D*B*R*F*5*2*H*6*6*A*8*2*X*X*|*1*7*4*1*0*9*8*|*S*5*6*0 *5*9*0*4*9*7*X*X*|*~*X*S*V*|*|*J*e*e*p*|*W*r*a*n*g*l*e*|*1*9 *9*7*|*1*J*4*F*Y*2*9*P*7*P*P*2*3*X*X*|*6*6*1*3*7*2*5*|*S*5*6 *0*5*9*0*4*9*7*X*X*|
So, obviously, the Split() parameter is being run as "null" or "" when the report is actually executing in order to split on every character.
I checked the source of the .rptdesign file and the split() function is only in there once. I have tried using both single and double quotes with the split() function parameters. I have tried using a "raw" RegExp as .split(/\|/) but that doesn't split on anything in the output, returning a single string, though it still works fine in the "Preview Results" window.
Has anyone else seen this kind of behavior?
| Re: split() in a computed column preview different from displayed in report [message #630372 is a reply to message #630314] |
Fri, 01 October 2010 14:59   |
Jason Weathersby Messages: 9167 Registered: July 2009 |
Chris,
I just tried this and I did not see the error. See my attached report:
Jason
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.21"
id="1">
<property name="createdBy">Eclipse BIRT Designer Version
2.5.2.v20100208 Build <2.5.2.v20100210-0630></property>
<property name="units">in</property>
<property name="iconFile">/templates/blank_report.gif</property>
<property name="bidiLayoutOrientation">ltr</property>
<property name="imageDPI">96</property>
<data-sources>
<script-data-source name="Data Source" id="7"/>
</data-sources>
<data-sets>
<script-data-set name="Data Set" id="8">
<list-property name="resultSetHints">
<structure>
<property name="position">0</property>
<property name="name">col1</property>
<property name="dataType">string</property>
</structure>
</list-property>
<list-property name="columnHints">
<structure>
<property name="columnName">col1</property>
</structure>
</list-property>
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
<property name="position">1</property>
</structure>
</list-property>
</structure>
<property name="dataSource">Data Source</property>
<method name="open"><![CDATA[ii=0;]]></method>
<method name="fetch"><![CDATA[if( ii > 0 ) return false;
row["col1"] =
" XSV||Mercedes-Benz|300M-V6|2006|WDBRF52H66A82XX|1741098|S560
590497XX|~XSV||Jeep|Wrangle|1997|1J4FY29P7PP23XX|6613725|S56 0590497XX|"
ii++;
return true;]]></method>
</script-data-set>
</data-sets>
<styles>
<style name="report" id="4">
<property name="fontFamily">sans-serif</property>
<property name="fontSize">10pt</property>
</style>
<style name="crosstab-cell" id="5">
<property name="borderBottomColor">#CCCCCC</property>
<property name="borderBottomStyle">solid</property>
<property name="borderBottomWidth">1pt</property>
<property name="borderLeftColor">#CCCCCC</property>
<property name="borderLeftStyle">solid</property>
<property name="borderLeftWidth">1pt</property>
<property name="borderRightColor">#CCCCCC</property>
<property name="borderRightStyle">solid</property>
<property name="borderRightWidth">1pt</property>
<property name="borderTopColor">#CCCCCC</property>
<property name="borderTopStyle">solid</property>
<property name="borderTopWidth">1pt</property>
</style>
<style name="crosstab" id="6">
</style>
</styles>
<page-setup>
<simple-master-page name="Simple MasterPage" id="2">
<page-footer>
<text id="3">
<property name="contentType">html</property>
<text-property
name="content"><![CDATA[<value-of>new Date()</value-of>]]></text-property>
</text>
</page-footer>
</simple-master-page>
</page-setup>
<body>
<table id="9">
<property name="dataSet">Data Set</property>
<list-property name="boundDataColumns">
<structure>
<text-property name="displayName">col1</text-property>
<expression name="expression"
type="javascript">dataSetRow["col1"]</expression>
</structure>
<structure>
<property name="name">Column Binding</property>
type="javascript">dataSetRow["col1"].split('|')[2];</expression >
</structure>
</list-property>
<column id="18"/>
<column id="22"/>
<header>
<row id="10">
<cell id="11">
<label id="12">
<text-property name="text">col1</text-property>
</label>
</cell>
<cell id="19"/>
</row>
</header>
<detail>
<row id="13">
<cell id="14">
<data id="15">
<property
name="resultSetColumn">col1</property>
</data>
</cell>
<cell id="20">
<data id="23">
<property name="resultSetColumn">Column
Binding</property>
</data>
</cell>
</row>
</detail>
<footer>
<row id="16">
<cell id="17"/>
<cell id="21"/>
</row>
</footer>
</table>
</body>
</report>
> Field3Test:
> Field3Test is:
> Results" window.
Jason Weathersby
BIRT Exchange
| Re: split() in a computed column preview different from displayed in report [message #630935 is a reply to message #630749] |
Tue, 05 October 2010 11:37   |
Chris,
This seems odd. Did you ever come up with an example that would
illustrate the issue?
Jason
On 10/4/2010 3:03 PM, Chris Chubb wrote:
> Well, I figured out the problem, but I still don't know why.
> In my original report I had added a factory method to add some logging
> when errors were encountered by end users, but then disabled it. Quote:
>> <report ....
>> <method name="beforeFactory"><![CDATA[importPackage(
>> Packages.java.util );
>> importPackage( Packages.java.lang );
>> importPackage(Packages.java.util.logging);
>> //var fileHandler = new FileHandler("/temp/birt.log", true);
>> //var rootLogger = Logger.getLogger("");
>> //rootLogger.addHandler(fileHandler);]]></method>
> When I removed that <method> block, the report works perfectly. When put
> back in, the split() function doesn't work in the report engine. Still
> no idea why importing two packages that I then don't use would affect
> the way it splits without throwing an error unless it has something to
> do with encoding of the text or the parameters.
> Jason, thanks again.
Jason Weathersby
BIRT Exchange
| Re: split() in a computed column preview different from displayed in report [message #630964 is a reply to message #630314] |
Tue, 05 October 2010 12:16   |
Junior Member |
Here is a sample report that demonstrates how the <method> tag messes up the split() function.
Because split() is acting like it's being called with a NULL or "" parameter, I am guessing that something in the Packages.java.lang package is setting or resetting a codepage (encoding) setting and that's messing up the params used in the method call. Would it overload split() and the method guesser is guessing the wrong method signature? I'm a bit out of my Java depth at this point...
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.21" id="1">
<property name="createdBy">Eclipse BIRT Designer Version 2.5.2.v20100208 Build <2.5.2.v20100210-0630></property>
]]></method>
<data-sources>
</data-sources>
<data-sets>
<structure>
</structure>
</list-property>
<structure>
</structure>
</list-property>
<structure>
</structure>
</list-property>
</structure>
ii=0;
]]></method>
row["col1"] = " XSV||Mercedes-Benz|300M-V6|2006|WDBRF52H66A82XX|1741098|S560590497XX|~XSV||Jeep|Wrangle|1997|1J4FY29P7PP23XX|6613725|S56 0590497XX|";
ii++;
return true;
]]></method>
</script-data-set>
</data-sets>
<styles>
</style>
</style>
</style>
</styles>
<page-setup>
<page-footer>
<text id="3">
<text-property name="content"><![CDATA[
]]></text-property>
</text>
</page-footer>
</page-setup>
<body>
<table id="9">
<structure>
<expression name="expression" type="javascript">dataSetRow["col1"]</expression>
</structure>
<structure>
<expression name="expression" type="javascript">dataSetRow["col1"].split('|')[2];</expression>
</structure>
<structure>
<property name="name">Column_Binding_1</property>
</structure>
</list-property>
<column id="18"/>
<column id="22"/>
<header>
<row id="10">
<cell id="11">
<property name="borderBottomColor">#000000</property>
<property name="borderBottomWidth">thin</property>
<property name="borderLeftColor">#000000</property>
<property name="borderLeftWidth">thin</property>
<property name="borderRightColor">#000000</property>
<property name="borderRightWidth">thin</property>
<property name="borderTopColor">#000000</property>
<property name="borderTopWidth">thin</property>
<label id="12">
</label>
</cell>
<cell id="19">
</cell>
</row>
</header>
<detail>
<row id="13">
<cell id="14">
<data id="15">
<property name="resultSetColumn">col1</property>
</data>
</cell>
<cell id="20">
<data id="23">
<property name="resultSetColumn">Column_Binding_1</property>
</data>
</cell>
</row>
</detail>
<footer>
<row id="16">
<cell id="17">
</cell>
<cell id="21">
</cell>
</row>
</footer>
</table>
</body>
</report>
[Updated on: Tue, 05 October 2010 14:16] Report message to a moderator
| Re: split() in a computed column preview different from displayed in report [message #631187 is a reply to message #630964] |
Wed, 06 October 2010 10:05  |
Chris,
I believe this has to do with the import of java lang. The expression is
trying to use the Java string split instead of the JavaScript function
split. If you take your example and use this expression
dataSetRow["col1"].split('\\|')[2];
it will work.
Jason
> parameter, I am guessing that something in one of those import packages
> id="1">
> <method name="beforeFactory"><![CDATA[importPackage( Packages.java.util );
> <data-sources>
> </data-sources>
> <data-sets>
> <structure>
> </structure>
> </list-property>
> <structure>
> </structure>
> </list-property>
> <structure>
> </structure>
> </list-property>
> </structure>
> ii=0;
> ]]></method>
> row["col1"] = "
> 0590497XX|";
> ii++;
> return true;
> ]]></method>
> </script-data-set>
> </data-sets>
> <styles>
> </style>
> </style>
> </style>
> </styles>
> <page-setup>
> <page-footer>
> <text id="3">
> ]]></text-property>
> </text>
> </page-footer>
> </page-setup>
> <body>
> <table id="9">
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> <column id="18"/>
> <column id="22"/>
> <header>
> <row id="10">
> <cell id="11">
> <label id="12">
> </label>
> </cell>
> <cell id="19">
> </cell>
> </row>
> </header>
> <detail>
> <row id="13">
> <cell id="14">
> <data id="15">
> </data>
> </cell>
> <cell id="20">
> <data id="23">
> </data>
> </cell>
> </row>
> </detail>
> <footer>
> <row id="16">
> <cell id="17">
> </cell>
> <cell id="21">
> </cell>
> </row>
> </footer>
> </table>
> </body>
> </report>
Jason Weathersby
BIRT Exchange
FUDForum. Page generated in 0.02182 seconds
