| NullPointer of some paintControl [message #630101] |
Thu, 30 September 2010 12:06  |
Hi, all:
My application runs into the following exception:
It looks like a NullPointer of some paintControl.
| Quote: | Exception in thread "main" java.lang.NullPointerException
at com.visionopen.jiapei.sm2d.VO_2DSMExplorer$2.paintControl(VO _2DSMExplorer.java:284)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:217)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1176)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1200)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1185)
at org.eclipse.swt.widgets.Control.gtk_expose_event(Control.jav a:2779)
at org.eclipse.swt.widgets.Composite.gtk_expose_event(Composite .java:670)
at org.eclipse.swt.widgets.Canvas.gtk_expose_event(Canvas.java: 170)
at org.eclipse.swt.widgets.Widget.windowProc(Widget.java:1566)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4587 )
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4191 )
at org.eclipse.swt.internal.gtk.OS._gtk_main_do_event(Native Method)
at org.eclipse.swt.internal.gtk.OS.gtk_main_do_event(OS.java:75 88)
at org.eclipse.swt.widgets.Display.eventProc(Display.java:1185)
at org.eclipse.swt.internal.gtk.OS._g_main_context_iteration(Na tive Method)
at org.eclipse.swt.internal.gtk.OS.g_main_context_iteration(OS. java:1860)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3110)
at com.visionopen.jiapei.sm2d.VO_2DSMExplorer.start(VO_2DSMExpl orer.java:475)
at com.visionopen.jiapei.sm2d.VO_2DSMExplorer.main(VO_2DSMExplo rer.java:748)
Well, I'm using SWT to draw my GUI, and urgently and sincerely expect some help from you guys. Please do give me a hand.
Best Regards
JIA
Welcome to Vision Open
http://www.visionopen.com
| Re: NullPointer of some paintControl [message #630663 is a reply to message #630101] |
Mon, 04 October 2010 09:52  |
Grant Gayed Messages: 2128 Registered: July 2009 |
The NPE is happening in
_2DSMExplorer.java:284), which is not part of swt. Can you tell us what in
this line has a null value that shouldn't?
Grant
"JIA Pei" <jp4work@gmail.com> wrote in message
news:i82cdb$aij$1@news.eclipse.org...
> Hi, all:
> Quote:
>> ner.java:217)
>> .java:670)
>> Method)
>> java:1860)
>> orer.java:475)
>> rer.java:748)
> Best Regards
> JIA
FUDForum. Page generated in 0.01521 seconds
