Home » Eclipse Projects » Buckminster » Buckminster cvs materializing, uses a proxy, how is this configured?
Buckminster cvs materializing, uses a proxy, how is this configured? [message #628738] Thu, 23 September 2010 17:02 Go to next message
Martin Taal is currently offline Martin Taal
When building texo/teneo job on hudson.eclipse.org buckminster tries to connect to the cvs server (dev.eclipse.org)
using a proxy server it seems.
When I check the .settings/org.eclipse.core.net.prefs in the build workspace (created by buckminster) I can see this in
the workspace settings:
proxyData/HTTP/hasAuth=false
proxyData/HTTP/host=proxy.eclipse.org
org.eclipse.core.net.hasMigrated=true
eclipse.preferences.version=1
proxyData/HTTP/port=9898
These settings are in this file:
https://hudson.eclipse.org/hudson/job/emft-texo-nightly/ws/b uild/build/workspace/.metadata/.plugins/org.eclipse.core.run time/.settings/org.eclipse.core.net.prefs/*view*/
Where do these proxy settings come from?
Here is the bugzilla where Matt (Eclipse Webmaster) comments on this also:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=325786
gr. Martin
[echo] Importing binaries into target platform
/opt/users/hudsonbuild/.hudson/jobs/emft-texo-nightly/worksp ace/build/build/tp
[java] com.jcraft.jsch.JSchException: ProxyHTTP: java.io.IOException:
proxy error: Forbidden
[java] at com.jcraft.jsch.ProxyHTTP.connect(ProxyHTTP.java:158)
[java] at
org.eclipse.jsch.internal.core.JSchProvider.connect(JSchProv ider.java:141)
[java] at
org.eclipse.team.internal.ccvs.core.connection.PServerConnec tion.open(PServerConnection.java:116)
[java] at
org.eclipse.team.internal.ccvs.core.connection.Connection.op en(Connection.java:132)
[java] at
org.eclipse.team.internal.ccvs.core.connection.CVSRepository Location.createConnection(CVSRepositoryLocation.java:545)
[java] at
org.eclipse.team.internal.ccvs.core.connection.CVSRepository Location.openConnection(CVSRepositoryLocation.java:806)
[java] at
org.eclipse.team.internal.ccvs.core.client.Session.open(Sess ion.java:159)
[java] at
org.eclipse.buckminster.cvspkg.internal.CVSSession.getReader Session(CVSSession.java:98)
[java] at
org.eclipse.buckminster.cvspkg.internal.RepositoryMetaData.g etMetaData(RepositoryMetaData.java:76)
[java] at
org.eclipse.buckminster.cvspkg.internal.VersionFinder.getMet aData(VersionFinder.java:97)
[java] at
org.eclipse.buckminster.cvspkg.internal.VersionFinder.getTru nk(VersionFinder.java:86)
[java] at
org.eclipse.buckminster.core.version.AbstractSCCSVersionFind er.getBestTrunkMatch(AbstractSCCSVersionFinder.java:320)
[java] at
org.eclipse.buckminster.core.version.AbstractSCCSVersionFind er.getBestVersion(AbstractSCCSVersionFinder.java:151)
[java] at
org.eclipse.buckminster.core.rmap.model.Provider.findMatch(P rovider.java:220)
[java] at
org.eclipse.buckminster.core.rmap.model.SearchPath.getProvid er(SearchPath.java:100)
[java] at
org.eclipse.buckminster.core.rmap.model.ResourceMap.resolve( ResourceMap.java:293)
[java] at
org.eclipse.buckminster.core.rmap.model.ResourceMap.resolve( ResourceMap.java:212)
[java] at
org.eclipse.buckminster.core.resolver.ResourceMapResolver.in nerResolve(ResourceMapResolver.java:202)
[java] at
org.eclipse.buckminster.core.resolver.ResolverNodeWithJob.re solve(ResolverNodeWithJob.java:190)
[java] at
org.eclipse.buckminster.core.resolver.ResolverNodeWithJob.ru n(ResolverNodeWithJob.java:87)
[java] at
org.eclipse.buckminster.core.resolver.ResolverNodeWithJob$No deResolutionJob.run(ResolverNodeWithJob.java:44)
[java] at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
[java] Caused by: java.io.IOException: proxy error: Forbidden
[java] at com.jcraft.jsch.ProxyHTTP.connect(ProxyHTTP.java:122)
[java] ... 21 more
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Buckminster cvs materializing, uses a proxy, how is this configured? [message #628840 is a reply to message #628738] Fri, 24 September 2010 07:34 Go to previous messageGo to next message
Michael Wenz is currently offline Michael Wenz
Hi Martin,
I have the same error in the Graphiti build. I think what is missing is the
list of hosts for which the proxy should be bypassed (on hudson.eclipse.org
this is configured as *.eclipse.org). It seems that this peace of
information is lacking when calling Buckminster from an ant script.
I added an experimental build step in gmp-graphiti-nightly that directly
calls Buckminster (via the Buckminster Hudson plugin). There the synching
from CVS works...
-Michael
"Martin Taal" <mtaal@elver.org> wrote in message
news:i7gf3i$tm2$1@news.eclipse.org...
> connect to the cvs server (dev.eclipse.org) using a proxy server it seems.
> workspace (created by buckminster) I can see this in the workspace
> settings:
> gr. Martin
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] ... 21 more
> The Netherlands
Re: Buckminster cvs materializing, uses a proxy, how is this configured? [message #629303 is a reply to message #628738] Mon, 27 September 2010 13:16 Go to previous messageGo to next message
Thomas Hallgren is currently offline Thomas Hallgren
On 09/23/2010 11:02 PM, Martin Taal wrote:
> settings:
I'm puzzled. I haven't seen this before. AFAIK, Buckminster has no code
that fiddles with proxy settings and I cannot find any preference
settings for org.eclipse.core.net in any of my workspaces. Are you using
a workspace template?
- thomas
Re: Buckminster cvs materializing, uses a proxy, how is this configured? [message #629308 is a reply to message #629303] Mon, 27 September 2010 14:16 Go to previous messageGo to next message
Yes, I am also surprised. Afaics I don't use a workspace template (how is this specified in buckminster?).
I launch buckminster like this:
<macrodef name="buckminster">
<attribute name="command" />
<attribute name="workspace" />
<element name="globargs" optional="true" />
<element name="cmdargs" optional="true" />
<sequential>
<eclipse.launch app="buckminster">
<args>
<jvmarg value="-Xmx1024m" />
<jvmarg value="-Dbugfix.288796=true" />
<arg value="-data" />
<arg value="@{workspace}" />
<arg value="--loglevel" />
<arg value="${buckminster.loglevel}" />
<arg value="--displaystacktrace" />
<arg value="@{command}" />
<globargs />
<arg value="-P" />
<arg value="${properties.tmp}" />
<cmdargs />
</args>
</eclipse.launch>
</sequential>
</macrodef>
After creating the workspace directory, one of the first things I do is this:
<echo message="Setting jre to ${env.JAVA_HOME}"/>
<buckminster command="installJRE" workspace="${workspacePath}">
<cmdargs>
<arg value="--location" />
<arg value="${env.JAVA_HOME}" />
</cmdargs>
</buckminster>
so I don't understand either where this proxy thing comes from...
gr. Martin
>> seems.
>> settings:
> - thomas
The Netherlands
Re: Buckminster cvs materializing, uses a proxy, how is this configured? [message #629330 is a reply to message #629303] Mon, 27 September 2010 15:49 Go to previous messageGo to next message
Henrik Lindberg is currently offline Henrik Lindberg
Other ways for these preferences to end up in the workspace could be:
- If reusing a workspace that was used earlier with the IDE
- Something is installed in headless buckminster that sets or modifies
the proxy preferences.
Do you see the preferences with a "vanilla" buckminster and a freshly
created workspace?
- henrik
Re: Buckminster cvs materializing, uses a proxy, how is this configured? [message #629505 is a reply to message #629330] Tue, 28 September 2010 09:27 Go to previous messageGo to next message
Hi Henrik,
This is a build run on hudson.eclipse.org, afaics I am not reusing an earlier workspace.
The strange thing is when I do the build locally it does not contain this setting. The local build is the same as the
hudson build afaics....
Is there something in buckminster which makes it run differently when run on hudson.eclipse.org?
gr. Martin
> created workspace?
> - henrik
The Netherlands
Re: Buckminster cvs materializing, uses a proxy, how is this configured? [message #629541 is a reply to message #629505] Tue, 28 September 2010 11:48 Go to previous messageGo to next message
If you mean that we have special code inserted to trap the fact that
it's running on specific servers or in a specific environment, the
answer is no.
What I could suspect is that the Eclipse proxy support performs some
kind of discovery on the network and auto-configures the proxy settings
depending on it's environment. Then again, that's just a wild guess.
- thomas
Re: Buckminster cvs materializing, uses a proxy, how is this configured? [message #629542 is a reply to message #629541] Tue, 28 September 2010 11:59 Go to previous messageGo to next message
Hi Thomas,
Yes this auto proxy setting maybe the cause, see an old post from a year back, you answered it :-)
http://dev.eclipse.org/mhonarc/lists/p2-dev/msg01955.html
I will research it further.
gr. Martin
The Netherlands
Re: Buckminster cvs materializing, uses a proxy, how is this configured? [message #630405 is a reply to message #629542] Fri, 01 October 2010 18:30 Go to previous message
This was solved!
To finish this thread. Michael Wenz pointed me to a change made in the cdo build (to solve this issue), a snippet from
his email to me:
But I saw that the CDO build is green again and they still do an Ant call from Hudson that again triggers Buckminster.
Previously that build failed with the same exception as ours did or do.
Not sure what these guys changed, but I saw that they added something in their build.xml that seems to fix this. I found
2 snippets that appear to be in connection with this:
<condition property="no.proxy" value="${env.no_proxy}, dev.eclipse.org" else="dev.eclipse.org">
<isset property="env.no_proxy" />
</condition>
<!-- Launch the eclipse application -->
<java fork="true" jar="${@{app}.launcher}" dir="${@{app}.deploy.dir}" failonerror="true">
<env key="no_proxy" value="${no.proxy}" />
<properties />
<!-- Uncomment to debug <jvmarg value=" -agentlib:jdwp=transport=dt_socket,address=8000,server=y,sus pend=y "/> -->
<args />
</java>
gr. Martin
On 09/28/2010 05:59 PM, Martin Taal wrote:
> Hi Thomas,
> gr. Martin
The Netherlands
Previous Topic:Resource .buckminster/tp is not local
Next Topic:How to debug: "No component XXX is known to Buckminster"?
Current Time: Mon May 20 00:35:50 EDT 2013
Powered by FUDForum. Page generated in 0.04495 seconds
