Home » Eclipse Projects » EclipseLink » add column in a table
add column in a table [message #630403] Fri, 01 October 2010 17:44 Go to next message
vicenrico  is currently offline vicenrico
Hello everybody.
This is the first time i use eclipselink and i would like to know if i this plus JPA can create automatically a column into the database.
I mean:
class persona{
int id;
String name;
etc...(i haven't set the @stuff)
I want to know, if i modify this class (for, example adding a new field, eclipselink+JPA will modify my table or i have to use "alter table" methods.
I tried to do, but i'm receiving :
"Column DNI not found; SQL statement:" error.
Re: add column in a table [message #630556 is a reply to message #630403] Mon, 04 October 2010 02:05 Go to previous message
Tom Eugelink is currently offline Tom Eugelink
AFAIK you can instruct JPA to automatically create tables, modifying I'm not sure. But personally I think databases are way to important to have them simply created by a library; I prefer using explicit SQL statements, so fields can be properly initialized, if required. If anything I'd use a library like liquibase.
Tom
On 1-10-2010 23:44, vicenrico wrote:
> Hello everybody.
> This is the first time i use eclipselink and i would like to know if i this plus JPA can create automatically a column into the database. I mean:
> class persona{
> int id;
> String name;
Previous Topic:EclipseLink JPA2.0 orm table name prefix help
Next Topic:Compatibility of TABLE_PER_CLASS inheritance strategy with composite keys
Current Time: Sun May 19 11:30:22 EDT 2013
Powered by FUDForum. Page generated in 0.01763 seconds
