Home » Modeling » Epsilon » EOL and feature maps
EOL and feature maps [message #629719] Wed, 29 September 2010 07:13 Go to next message
Hallvard Traetteberg is currently offline Hallvard Traetteberg
I'm using ETL/EOL in the context of an XHTML model (from a QVTO example
I found a reference to). This model uses FeatureMaps heavily and I'm now
struggling with the EOL for adding elements.
If I understand this correctly, a feature map is a way of storing a list
of entry elements, so that the values of the entries also appear in a
set of derived features. In the XHTML model, a Block contains a groups
FeatureMap, and there are derived multi-value references named p, h1,
.... When you add a P to the Block, I believe you have to create an
Entry, set the key to Block's p feature and the value to the new P. Then
the Entry is added to the FeatureMap. There is a convenience method in
FeatureMap for adding the key, value pair. In any case, I have to be
able to get hold of an EPackage instance and ask for a specific
EStructuralFeature, e.g. XhtmlPackage.eINSTANCE.getBlock_P();
I haven't found a way of calling static methods, but know about Native
technique. The question is, do I have to define a new Tool with my own
methods for accessing "static" information, like the EPackage registry?
Hallvard
Re: EOL and feature maps [message #629912 is a reply to message #629719] Wed, 29 September 2010 17:54 Go to previous messageGo to next message
I managed to solve it, twice in fact. First, I implemented a tool that
exposed necessary method for handling FeatureMaps, and used this by
initializing it in a pre block and using it when needed. Second, I
realized that I only needed methods on objects I already had access to
by means of eClass(). E.g. I could lookup features in the eClass, get
feature values, add values to features maps, etc, using only EOL.
Hallvard
> Hallvard
Re: EOL and feature maps [message #629986 is a reply to message #629912] Thu, 30 September 2010 04:03 Go to previous messageGo to next message
Dimitrios Kolovos is currently offline Dimitrios Kolovos
Hi Hallvard,
Glad you managed to solve this! For XML-based models you may also want
to have a look at the plain XML driver we recently added to Epsilon:
http://www.eclipse.org/gmt/epsilon/doc/articles/plain-xml/
Dimitris
> Hallvard
>> Hallvard
Re: EOL and feature maps [message #630168 is a reply to message #629986] Thu, 30 September 2010 17:05 Go to previous message
Interesting! Although the example I'm working on now is for a lecture
(tomorrow morning) about M2M transformations (followed up by M2T with
EGL using the the same example). Hence, it's better to have an explicit
Ecore model of XHTML (found one in a QVTO example in Eclipse's CVS).
Hallvard
Previous Topic:Problem using `pre` to declare global data
Next Topic:need help in ETL transformation rules
Current Time: Thu May 23 14:25:59 EDT 2013
Powered by FUDForum. Page generated in 0.09379 seconds
