| Re: UnsupportedOperationException with 3 repositories [message #632505 is a reply to message #632104] |
Wed, 13 October 2010 05:04   |
Filip Hrbek Messages: 233 Registered: July 2009 |
Hello Lars,
I have found & fixed the bug. However, we have problems setting up a hudson build for updating the site on the new Eclipse build server. Stay tuned, I hope we'll fix it within a few days.
Filip
On 11.10.2010 16:36, Lars Fischer wrote:
> Hello Filip,
> I apologize for asking again.
> On 01.10.2010 10:14, Lars Fischer wrote:
>>> Could you please enter a bugzilla issue and attach your b3aggr file so
>>> that both of us would work with exactly the same thing?
>>> In addition to this, let me know which version of b3 aggregator you are
>>> using. Thanks.
>> I filed a new issue at https://bugs.eclipse.org/bugs/show_bug.cgi?id=326742
> Is there something else, what I could provide to you?
> Lars
| Re: UnsupportedOperationException with 3 repositories [message #640521 is a reply to message #640504] |
Mon, 22 November 2010 07:24   |
Yes, we are already able to build it. The latest build is supposed to be published later today to the 3.6 update site, and we will also modify the build for 3.7milestones (currently there is a new build but it is actually based on 3.6 and we want to change it to 3.7).
I'll let you know when it all gets stable (hopefully later today).
Filip
Dne 22.11.2010 12:25, Lars Fischer napsal(a):
>> No problem, I will watch this group.
> Are there any news about a new build?
> Lars
| Re: UnsupportedOperationException with 3 repositories [message #641083 is a reply to message #640521] |
Wed, 24 November 2010 03:36   |
The new build for 3.6 is now available. Please try it out to see if it fixes your problem.
Filip
Dne 22.11.2010 13:24, Filip Hrbek napsal(a):
> Filip
>> Regards,
>> Lars
| Re: UnsupportedOperationException with 3 repositories [message #641230 is a reply to message #641197] |
Wed, 24 November 2010 10:19  |
Lars Fischer Messages: 105 Registered: July 2009 |
On 24.11.2010 15:19, Lars Fischer wrote:
> I tried to first uninstall the old aggregator, but there is still an
> error. Trying to use a clean Eclipse 3.6.1 may take some time.
> Does this error also belong to Bug 327234?
Some update tries later: now its running fine.
Lars
FUDForum. Page generated in 0.03195 seconds
