Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [EMF Compare] Duplicate differences into DiffModel
[EMF Compare] Duplicate differences into DiffModel [message #630097] Thu, 30 September 2010 11:33 Go to next message
Julien is currently offline Julien
I'm comparing two UML Models exported from MagicDraw with the EMF UML2
XMI export feature.
In the DiffModel, it seems that there are many duplicated elements. Here
is an output from myDiffModel.getDifferences():
org.eclipse.emf.ecore.impl.EAnnotationImpl@353f6a (source:
http://www.eclipse.org/uml2/2.0.0/UML) has been added
org.eclipse.emf.ecore.impl.EAnnotationImpl@13a1398 (source:
http://www.eclipse.org/uml2/2.0.0/UML) has been removed
org.eclipse.emf.ecore.impl.EAnnotationImpl@2f7d55 (source:
org.eclipse.emf.ecore.impl.EAnnotationImpl@1ea15f2 (source:
org.eclipse.emf.ecore.impl.EAnnotationImpl@1828374 (source:
org.eclipse.emf.ecore.impl.EAnnotationImpl@12eafbf (source:
org.eclipse.emf.ecore.impl.EAnnotationImpl@1f528dc (source:
org.eclipse.emf.ecore.impl.EAnnotationImpl@1173370 (source:
org.eclipse.emf.ecore.impl.EAnnotationImpl@111cccd (source:
org.eclipse.emf.ecore.impl.EAnnotationImpl@4e19c1 (source:
org.eclipse.emf.ecore.impl.EAnnotationImpl@47f959 (source:
org.eclipse.emf.ecore.impl.EAnnotationImpl@5962c4 (source:
org.eclipse.emf.ecore.impl.EAnnotationImpl@39f7bc (source:
org.eclipse.emf.ecore.impl.EAnnotationImpl@186dbbb (source:
org.eclipse.emf.ecore.impl.EAnnotationImpl@68969c (source:
org.eclipse.emf.ecore.impl.EAnnotationImpl@2365fe (source:
org.eclipse.uml2.uml.internal.impl.LiteralUnlimitedNaturalIm pl @1e431c2
(name: , visibility: <unset>) (value: 1) has been added
org.eclipse.uml2.uml.internal.impl.LiteralIntegerImpl@7ef926 (name: ,
visibility: <unset>) (value: 0) has been added
org.eclipse.uml2.uml.internal.impl.LiteralIntegerImpl@110fdb4 (name: ,
visibility: <unset>) (value: 1) has been removed
org.eclipse.uml2.uml.internal.impl.LiteralUnlimitedNaturalIm pl @3ff589
(name: , visibility: <unset>) (value: 1) has been removed
org.eclipse.emf.ecore.impl.EAnnotationImpl@193618e (source:
org.eclipse.emf.ecore.impl.EAnnotationImpl@3ed23c (source:
org.eclipse.emf.ecore.impl.EAnnotationImpl@1cbbe6 (source:
org.eclipse.emf.ecore.impl.EAnnotationImpl@33f0d1 (source:
org.eclipse.emf.ecore.impl.EAnnotationImpl@32bbcc (source:
org.eclipse.emf.ecore.impl.EAnnotationImpl@15771a2 (source:
org.eclipse.emf.ecore.impl.EAnnotationImpl@4a3993 (source:
org.eclipse.emf.ecore.impl.EAnnotationImpl@1da07be (source:
org.eclipse.emf.ecore.impl.EAnnotationImpl@32d6e7 (source:
org.eclipse.emf.ecore.impl.EAnnotationImpl@130faf3 (source:
Only Four lines are relevant, Can someone explain to me why i have
duplicate lines?
Julien
Re: [EMF Compare] Duplicate differences into DiffModel [message #633051 is a reply to message #630097] Fri, 15 October 2010 04:26 Go to previous message
Laurent Goubet is currently offline Laurent Goubet
--------------040400020708060900060901
Hi Julien,
Please use the EMF newsgroup for questions regarding EMF Compare.
The duplicate lines come from us not being able to properly match UML
elements. The generatic engines of EMF Compare has issues with UML
annotations, sterotypes... You'll have to subclass the
GenericMatchEngine to specifically match UML elements according to your
needs.
Laurent Goubet
Obeo
Julien wrote:
> XMI export feature.
> duplicate lines?
> Cheers,
> Julien
Content-Type: text/x-vcard; charset=utf-8;
name="laurent_goubet.vcf"
Content-Disposition: attachment;
filename="laurent_goubet.vcf"
begin:vcard
fn:Laurent Goubet
n:Goubet;Laurent
org:<a href="http://www.obeo.fr">Obeo</a>
email;internet:laurent.goubet@obeo.fr
url:http://www.obeo.fr
version:2.1
end:vcard
--------------040400020708060900060901--
Previous Topic:[TEXO] XML serialization for arraylist
Next Topic:[EMF Compare] Is it possible to ignore the element order?
Current Time: Wed May 22 01:30:02 EDT 2013
Powered by FUDForum. Page generated in 4.49615 seconds
