| Problem using `pre` to declare global data [message #629547] |
Tue, 28 September 2010 12:16  |
Andy Ed Messages: 41 Registered: December 2009 |
Member |
I'm having a problem sharing data between rules/operation using the following style (using pre to declare 'globals').
pre{
var storedIniValues := new OrderedSet;
operation op1(){
var item := new m!elem;
storedIniValues .add(item);
Sometimes this approach does work, sometimes not; with my current problem I get an exception stating that Type storedIniValues is not found. Do you have any ideas why this approach works sometimes but not others?
cheers, Andy
FUDForum. Page generated in 0.01665 seconds
