Home » Modeling » AMW » How to simple ATL
How to simple ATL [message #559549] Fri, 17 September 2010 02:45 Go to next message
masato  is currently offline masato
I'd like to make ATL file from simple ATL transformation.
I was able to make rule.
but I could not make helper and if-else into rule.
How Can AMW-Module make them?
or
Need to edit to direct in atl file?
Please tell me.
masato
Re: How to simple ATL [message #629619 is a reply to message #559549] Tue, 28 September 2010 20:23 Go to previous message
Marcos Didonet Del Fabro is currently offline Marcos Didonet Del Fabro
Member
the existing extensions of AMW only support simple ATL code, so you can develop something like a skeleton using the graphical interface.
In order to have more complex code, you need to create your own extensions, or manually improve the generated ATL.
Marcos.
Previous Topic:Problem in AMWtoATL(HOT)
Next Topic:Error in Content Help of Model Weaver Plug-in User Guide
Current Time: Tue May 28 08:27:02 EDT 2013
Powered by FUDForum. Page generated in 0.01673 seconds
