| Hide column in TableCombo. [message #629137] |
Mon, 27 September 2010 06:41  |
Neha Messages: 52 Registered: July 2009 |
Member |
Hi All,
In my application I need to hide a column of tablecombo and use the same
hidden column index as display column index. Is there a way to do so ?
Please do let me know.
I tried the following way
TableComboViewer tableComboViewer = new TableComboViewer(composite,
SWT.READ_ONLY | SWT.BORDER);
TableCombo tableCombo = tableComboViewer.getTableCombo();
tableCombo.setShowImageWithinSelection(false);
tableCombo.setLayoutData(new GridData(125, SWT.DEFAULT));
tableCombo.setVisibleItemCount(10);
tableCombo.setShowTableHeader(true);
tableCombo.defineColumns(new String[] { "ID", "Name", "Combo Text" },
new int[] { 60, 100, 0 });
tableCombo.setDisplayColumnIndex(2);//use display index of hidden col
tableComboViewer.setContentProvider(new ArrayContentProvider());
tableComboViewer.setLabelProvider(new LabelProvider());
int iCounter;
for (iCounter = 0; iCounter < 3; iCounter++) {
ColumnSelectionListenerForTableCombo colListener = new
ColumnSelectionListenerForTableCombo(
iCounter, tableComboViewer, componentType);
tableCombo.getTable().getColumn(iCounter).addSelectionListen er(
colListener);
tableCombo.getTable().getColumn(2).setWidth(0);//set width of column to be
hidden to 0
tableCombo.getTable().getColumn(2).setResizable(false)
tableCombo.redraw();
But it doesnt seem to be working.
| Re: Hide column in TableCombo. [message #629471 is a reply to message #629162] |
Tue, 28 September 2010 08:16  |
Member |
Hi Marty,
Thanks for your reply.
Ans to your questions
1. I m using windows xp. version 5.1,service pack 3
2.Eclipse:
Version: 3.4.1
Build id: M20080911-1700
"Marty Jones" <martybjones@gmail.com> wrote in message
news:i7q0kh$ics$1@news.eclipse.org...
>I modified the TableComboSnippet1 class on the sample #5 as follows:
> // tell the TableCombo that I want 3 columns autosized with the following
> column headers.
> //tc.defineColumns(new String[] { "Id", "Description", "Computed"});
> tc.defineColumns(new String[] { "Id", "Description", "Computed" },
> This made the third column hidden and also when a item was selected in the
> combo, the third column's text displayed in the selection box. So
> everything seems to be working fine for me.
> A few questions:
> 1. What OS are you running?
> 2. What version of Eclipse are you running?
FUDForum. Page generated in 0.01489 seconds
