Home » Eclipse Projects » EGit » Status of .gitignore awareness in 0.9?
Status of .gitignore awareness in 0.9? [message #582583] Wed, 25 August 2010 08:47 Go to next message
Janosch  is currently offline Janosch
EGit does not recognize folders in my .gitignore file. I have several projects in one directory which share a .gitignore file.
root_folder/
- project_1
- project_2
- .gitignore
My top level .gitignore file contains "CMakeFiles/". According to the gitignore specs, this should make git ignore all folders with that name no matter where they appear in the file hierarchie.
However every "CMakeFiles/" folder is marked by EGit as "untracked".
BTW, it works great with files. They are ignored in the whole file hierarchie if they are set in the top level gitignore file. But folders do not seem to work.
I use the EGit nightlies (0.9.0.201008171311).
cheers,
Janosch
Re: Status of .gitignore awareness in 0.9? [message #582674 is a reply to message #582583] Tue, 14 September 2010 14:38 Go to previous messageGo to next message
Chris Aniszczyk is currently offline Chris Aniszczyk
On 8/25/10 7:47 AM, Janosch wrote:
> root_folder/
> - project_1
> - project_2
> - .gitignore
Can you file a bug for this?
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=EGit
It should work.
Chris Aniszczyk
http://aniszczyk.org
+1 860 839 2465
Re: Status of .gitignore awareness in 0.9? [message #628924 is a reply to message #582674] Fri, 24 September 2010 13:56 Go to previous message
Done. https://bugs.eclipse.org/bugs/show_bug.cgi?id=326180
Previous Topic:An egit push does not change my files
Next Topic:Conflict resolution graphical editor (like subclipse)
Current Time: Thu May 23 12:07:11 EDT 2013
Powered by FUDForum. Page generated in 0.06968 seconds
