Home » Eclipse Projects » Test and Performance Tools Platform (TPTP) » Can't open analysis in Eclipse Workbench
Can't open analysis in Eclipse Workbench [message #628815] Fri, 24 September 2010 04:40 Go to next message
Stephan Arenswald is currently offline Stephan Arenswald
Hi All,
I set up TPTP 4.7 and I'm now trying to profile my application. When I
start the profiling (either using the Profile As... menu or the
-agentlib parameter) the profiling starts and Eclipse asks me to switch
to the Profiling and Logging perspective. I click yes and can see an
entry in the Profiling Monitor view for my process. But when I double
click on Execution Time Analysis for my process nothing happens. So can
not see the execution statistics (basically the tab just doesn't open).
What am I doing wrong?
Re: Can't open analysis in Eclipse Workbench [message #628845 is a reply to message #628815] Fri, 24 September 2010 08:14 Go to previous messageGo to next message
Fabio  is currently offline Fabio
Same here.
I'm using the integrated agent controller and if I manually run ACStart.sh and SampleClient everithing is working.
But when I profile my applications I cannot see any profiling views: if I right click on the profile monitor view I cannot see the "open with" entry.
[Updated on: Fri, 24 September 2010 08:18]
Report message to a moderator
Re: Can't open analysis in Eclipse Workbench [message #628871 is a reply to message #628845] Fri, 24 September 2010 10:28 Go to previous messageGo to next message
Under the menu WIndows -> Show views -> Other I don't see any of these views:
* UML2 Trace Interaction views
* Execution Flow view
* Execution Statistics view
* Code Coverage Statistics
* Object references table
* Memory Statistics view
* Object Allocations view
* Thread Statistics view
Is it correct or I'm missing some tptp subcomponent ?
Re: Can't open analysis in Eclipse Workbench [message #628882 is a reply to message #628815] Fri, 24 September 2010 11:21 Go to previous messageGo to next message
Joel Cayne is currently offline Joel Cayne
The profiling views are contributed as part of the TPTP Trace Project. You can check to see if the feature containing these views are installed through the Help -> About Eclipse menu, selecting the Features tab in Installation Details and verifying the TPTP Trace feature is installed (org.eclipse.tptp.trace Feature Id).
If this feature is missing, the TPTP Installation Guide describes the different options for installation.
Re: Can't open analysis in Eclipse Workbench [message #628975 is a reply to message #628882] Sat, 25 September 2010 03:08 Go to previous messageGo to next message
I was missing the TPTP Trace component....
Thanx!
Re: Can't open analysis in Eclipse Workbench [message #629736 is a reply to message #628882] Wed, 29 September 2010 08:21 Go to previous message
Same for me. I also missed to install the tracing component.
Thanks a lot.
Previous Topic:Plans for upcoming TPTP releases
Next Topic:TPTP 4.7.1 is released!
Current Time: Thu May 23 22:40:52 EDT 2013
Powered by FUDForum. Page generated in 0.01902 seconds
