MagicDraw does not use Eclipse UML2 as its native format (yet), so this is not the right forum for that kind of question. You might want to ask that on the MagicDraw support forum.
wafaa Messages: 163 Registered: January 2010 Location: Egypt
thanks Rafeal but I usually creates diagrams in magicdraw and export them as UML2 and they are opened in Eclipse.
I did not understand your answer, is it that my diagrams are opened due to their correct UML format not because it is the standard for magicdraw, magicdraw uses many standards.
but the error shows that the problem is that because the file is somehow UML1.4 which is not supported by magicdraw
but far away fro this problem cant i convert it to UML2 though??
I will try to find the MagicDraw forum if it exists??
On 11/07/1431 09:56 ص, Rafael Chaves wrote:
> Oh, I see what you mean now. All you want is to be able to open a UML
> 1.4 model using the Eclipse UML2 API.
> This thread might be of interest:
> http://www.eclipse.org/forums/index.php?t=tree&goto=4753 23
thanks a lot rafeal for you help and informative reply, I wonder if I
can have more information on endlinkData and related operation!!:D
