Home » Modeling » UML2 » setNamespace / setOwner ?
setNamespace / setOwner ? [message #528930] Thu, 22 April 2010 08:41 Go to next message
Itamar is currently offline Itamar
Member
Is there an API call to set an Element's owner? (e.g. set a Class's owning Package / set an Operation's owning Class)
Re: setNamespace / setOwner ? [message #529592 is a reply to message #528930] Mon, 26 April 2010 09:48 Go to previous messageGo to next message
Christian W. Damus is currently offline Christian W. Damus
Hi, Itamar,
The most conventional way to set the owner of any element is to add that
element to the appropriate containment reference of its intended parent.
e.g.,
someClass.getOwnedOperations().add(someOperation)
Some containments have settable inverses, but probably not all, so it's
easiest just to work top-down.
Christian
Re: setNamespace / setOwner ? [message #529870 is a reply to message #529592] Tue, 27 April 2010 10:21 Go to previous messageGo to next message
Member
Thanks!
I was sure I tried this.. Anyway, it works. Thank you.
Re: setNamespace / setOwner ? [message #628414 is a reply to message #529592] Tue, 27 April 2010 10:21 Go to previous message
Member
Thanks!
Previous Topic:Ecore 2 Uml conversion question
Next Topic:[Announce] Webinar: CDO Model Repository - Apr. 29
Current Time: Tue May 21 16:32:57 EDT 2013
Powered by FUDForum. Page generated in 0.01816 seconds
