Home » Modeling » UML2 » generating metamodel extensions based on CacheAdapter
generating metamodel extensions based on CacheAdapter [message #628187] Tue, 12 January 2010 22:48 Go to next message
Rafael Chaves is currently offline Rafael Chaves
I tried setting the 'Cache Adapter Support' property in the genmodel for a metamodel extension library, to no avail, the code generated does not use CacheAdapter at all.
Are there other requirements for code generation to include cache adapter support?
Rafael
Re: generating metamodel extensions based on CacheAdapter [message #628188 is a reply to message #628187] Tue, 12 January 2010 23:16 Go to previous message
Ok, so in addition to enabling cache adapter support, each element has to have a cache scope != "none". I noticed the UML.genmodel has an attribute cacheAdapterScope="Resource" in its elements, just don't know how to expose that in the genmodel editor.
Previous Topic:generating metamodel extensions based on CacheAdapter
Next Topic:[Fixed]Problem when i Unload a UML resource and reload it
Current Time: Thu May 23 08:58:37 EDT 2013
Powered by FUDForum. Page generated in 0.02259 seconds
