Home » Modeling » UML2 Tools » Sequence Diagram with Eclipse
Sequence Diagram with Eclipse [message #625523] Thu, 04 March 2010 01:53 Go to next message
No real name is currently offline No real name
We have created a tool for Reverse Engineering any Java application, which creates dynamic UML Sequence Diagrams and Class Diagrams.
All you have to do is just run your application and sit back. Reverse Java runs in background tracing all the activities happening inside your application and creates UML diagram for you. You can get more details at
http://www.reversejava.com
I would like to enhance the capability of the tool by integrating it with Eclipse, where by users after viewing the Sequence diagram can also edit it.
Can some please recommend me any APIs which I can use for this?
Thanks and Regards,
Rajesh Jadhav.
Re: Sequence Diagram with Eclipse [message #625524 is a reply to message #625523] Thu, 04 March 2010 05:15 Go to previous message
Ed Merks is currently offline Ed Merks
Rajesh,
Please avoid cross posting the same question to multiple groups. Both
the UML2 and UML2Tools projects publish SDKs with APIs you can use.
They're build on things like EMF and GMF which also publish SDKs.
> details at
> also edit it.
> Thanks and Regards,
> Rajesh Jadhav.
Previous Topic:Sequence Diagram with Eclipse
Next Topic:How to retrieve the current package?
Current Time: Sun May 19 13:14:31 EDT 2013
Powered by FUDForum. Page generated in 0.04492 seconds
