| Trying to define attribute in class in diagram of type "Set<ComponentType>" [message #625320] |
Thu, 03 December 2009 15:03  |
David M. Karr Messages: 329 Registered: July 2009 |
I have a simple class diagram, with classes "Catalog" and "Category". I'll be adding many more classes, but these are the first two. There is a property of "Catalog" called "rootCategories", which should be a "Set<Category>". It's easy enough to define an association from Catalog to Category and label it on the source end with "rootCategories", but I'd like to define a "rootCategories" attribute of "Catalog" of type "Set<Category>".
I've created the two class icons, along with the association, but I don't understand the steps required to get that attribute created with that type.
| Re: Trying to define attribute in class in diagram of type "Set<ComponentType>" [message #625326 is a reply to message #625320] |
Fri, 04 December 2009 09:02  |
Ed Merks Messages: 24538 Registered: July 2009 |
David,
Your question appears to be about Java generics but that isn't directly
supported by UML itself. I suppose something equivalent is a
multi-valued property that's unordered and unique, but even this, if
mapped to Ecore and then to Java will result in EList<Category> not
Set<Category>...
> that type.
FUDForum. Page generated in 0.01536 seconds
