Home » Modeling » UML2 Tools » Display UML 2 class diagram
Display UML 2 class diagram [message #625317] Wed, 02 December 2009 12:42 Go to next message
Erik Putrycz is currently offline Erik Putrycz
I'd like to display UML2 diagrams in my application. Is there any way to reuse the uml2 editor for display only?
Re: Display UML 2 class diagram [message #625318 is a reply to message #625317] Thu, 03 December 2009 06:33 Go to previous messageGo to next message
Vlad Varnica is currently offline Vlad Varnica
What do you mean by display only ?
Is-it to create a class diagram manually or programmatically ?
is-the diagram information coming from source code, from a model from ........ ?
You need to explain in the post what you expect, why and even how you think it should work.
Re: Display UML 2 class diagram [message #625319 is a reply to message #625318] Thu, 03 December 2009 09:47 Go to previous message
Vlad Varnica wrote on Thu, 03 December 2009 06:33
I'd like to load a .uml file and display a class diagram inside a widget. There are other actions I'd like the user to do but they don't involve editing the uml diagram itself.
Vlad
> Is the diagram information coming from source code, from a model from ........ ?
The diagram would come from a uml xmi file. I was wondering if there would be ways to reuse some of the uml tools to read the uml file and display a class diagram.
Previous Topic:Trouble using UML 2.1 Class Diagram Wizard (newbie)
Next Topic:Where are the UML2 Tools sample projects?
Current Time: Fri May 24 13:47:16 EDT 2013
Powered by FUDForum. Page generated in 0.02347 seconds
