Home » Eclipse Projects » Eclipse Communications Framework (ECF) » Can't connect to ECF server
Can't connect to ECF server [message #625272] Mon, 21 June 2010 13:58 Go to next message
Tom  is currently offline Tom
I've tried connecting to ECF server just as described in the wiki. but I'm getting an error message:
can anyone tell me what am I doing wrong?
tnx
Re: Can't connect to ECF server [message #625273 is a reply to message #625272] Tue, 22 June 2010 03:01 Go to previous messageGo to next message
Markus Kuppe is currently offline Markus Kuppe
What kind of error message do you get and what is the server url? If it
is ecftcp://ecf.eclipse.org:3282/server I am not the server is up and
running. So you might want to try connecting to your own instance of ECF
generic server.
Markus
Re: Can't connect to ECF server [message #625357 is a reply to message #625272] Fri, 02 July 2010 14:23 Go to previous messageGo to next message
First of all I would like to apologize it took me so long to respond back. I tried to upgrade my Ubuntu distro in hope it will fix some problems, it ended up just causing more.
now, for the error message in text form:
Title:
"Connection failed"
Content:
"Could not connect to ecftcp://ecf.eclipse.org:3282/server
Reason:
exception during connection to ecftcp://ecf.eclipse.org:3282/server"
Details:
"Connection refused"
and about Scott's post, I am very sorry for the ignorance but could you please guide me step by step from the main window in eclipse, because I really don't know where to find this bundle.
tnx.
Re: Can't connect to ECF server [message #625358 is a reply to message #625357] Sat, 03 July 2010 03:40 Go to previous message
> Title: "Connection failed"
> Content: "Could not connect to ecftcp://ecf.eclipse.org:3282/server
> Reason:
> Details:
There is no server running at ecftcp://ecf.eclipse.org:3282/server You
will have to setup your own instance as described in the wiki [0].
Markus
[0] http://wiki.eclipse.org/ECF_Servers
Previous Topic:Concrete problem but no experiences with ECF
Next Topic:Can't connect to ECF server
Current Time: Mon May 20 02:59:20 EDT 2013
Powered by FUDForum. Page generated in 0.01761 seconds
