Home » Eclipse Projects » Eclipse Communications Framework (ECF) » Share Editor with Open Fire XMPPS
Share Editor with Open Fire XMPPS [message #625192] Fri, 09 April 2010 11:35 Go to next message
Scott Selvia is currently offline Scott Selvia
I am able to setup and communicate via eclipse with another developer in the building. However when we share and editor session they can only see my changes, I cannot see there changes. If we use the ECF server we can see both changes.
I was hoping to take advantage of the open fire server the company has setup and not have to have the ECF server as well.
We are using openfire 3.6.4 with eclipse 3.5.2 and ECF 3.0.1.v20090916-2238 downloaded via the Collaboration->Eclipse Communication Framework SDK update site.
Any suggestions on why the first party cannot see the other persons edits
Re: Share Editor with Open Fire XMPPS [message #625193 is a reply to message #625192] Fri, 09 April 2010 12:09 Go to previous messageGo to next message
We just downloaded and installed the latest ECF SDK from the ECF site and it still does not work. The second party can see my edits but I cannot see there's when using XMPPS.
Re: Share Editor with Open Fire XMPPS [message #625194 is a reply to message #625193] Fri, 09 April 2010 13:33 Go to previous message
found an old post that I submitted over a year ago, in order for this to work with openfire you have to use machinename.domainname for the openfire server durring setup. Finally, if you want to use chat rooms in eclipse you cannot use a password. If you do then you will get an exception and it won't connect.
Previous Topic:XMPP
Next Topic:Share Editor with Open Fire XMPPS
Current Time: Sat May 25 04:47:38 EDT 2013
Powered by FUDForum. Page generated in 0.01580 seconds
