| Re: Testing Help Runtime [message #624187] |
Fri, 18 June 2010 14:46  |
Miles Parker Messages: 1266 Registered: July 2009 |
Chris Goldthorpe wrote on Fri, 18 June 2010 14:27
> I can't see from the log why it is failing - the infocenter started with no problem for me using 3.6RC4. Maybe the port is in use.
Yeah, I just tried it again and this time I got some kind of bundle issue. Looks like I've left something out, but rather than spend time on it I just ran with all plugins. That doesn't actually take that long since there is no UI. For the record, here's the error log:
!ENTRY org.eclipse.help.base 4 0 2010-06-16 17:59:39.215!MESSAGE Help cannot be displayed. The embedded application server could not ru
n help web application.!STACK 0
java.lang.NullPointerException at org.eclipse.help.internal.server.JettyHelpServer.checkBundle (JettyHel
pServer.java:112)
at org.eclipse.help.internal.server.JettyHelpServer.start(Jetty HelpServer.java:103)
at org.eclipse.help.internal.server.WebappManager.start(WebappM anager.java:38)
at org.eclipse.help.internal.base.BaseHelpSystem.ensureWebappRu nning(Bas
eHelpSystem.java:182)
FUDForum. Page generated in 0.01683 seconds
