| Create a ECF Server [message #624003] |
Wed, 30 July 2008 12:40 |
Cyril Lakech Messages: 4 Registered: July 2009 |
Junior Member |
I'd like to create a ECF Server in order to work with ECF with my dev team.
I think we can't use the default ecf server cause he is public.
So we have to create our ECF Server based on Eclipse/Equinox/ECF SDK
I read a few threads and wiki pages but i can't managed to run my ECF server.
Could someone shared is packaged server (with config.ini) ?
Could someone help ?
I try with ECF 2.0 for Eclipse 3.3 and ECF 2.0 for Eclipse 3.4.
I use Equinox 3.2 and 3.4
Here is my logs :
config.ini:
osgi.bundles=org.eclipse.equinox.common@2:start, org.eclipse.update.configurator@3:start, org.eclipse.core.runtime@start
eclipse.ignoreApp=true
osgi.noShutdown=true
eclipse.application.registerDescriptors=true
I got some troubles with org.eclipse.core.contenttype so i add it to plugins dir.
I redirect the command to a file :
Install location:
file:/d:/eclipseB/
Configuration file:
file:/d:/eclipseB/configuration/config.ini loaded
Configuration location:
Framework located:
file:/d:/eclipseB/plugins/org.eclipse.osgi_3.4.0.v20080605-1 900.jar
Framework classpath:
Splash location:
null
Debug options:
file:/D:/eclipseB/.options not found
osgi> java.io.IOException: Descripteur non valide
at java.io.FileInputStream.readBytes(Native Method)
at java.io.FileInputStream.read(FileInputStream.java:194)
at java.io.BufferedInputStream.read1(BufferedInputStream.java:2 20)
at java.io.BufferedInputStream.read(BufferedInputStream.java:27 7)
at java.io.FilterInputStream.read(FilterInputStream.java:111)
at sun.nio.cs.StreamDecoder$CharsetSD.readBytes(StreamDecoder.j ava:408)
at sun.nio.cs.StreamDecoder$CharsetSD.implRead(StreamDecoder.ja va:450)
at sun.nio.cs.StreamDecoder.read(StreamDecoder.java:182)
at java.io.InputStreamReader.read(InputStreamReader.java:167)
at java.io.BufferedReader.fill(BufferedReader.java:136)
at java.io.BufferedReader.readLine(BufferedReader.java:299)
at java.io.BufferedReader.readLine(BufferedReader.java:362)
at org.eclipse.osgi.framework.internal.core.FrameworkConsole.co nsole(FrameworkConsole.java:275)
at org.eclipse.osgi.framework.internal.core.FrameworkConsole.ru n(FrameworkConsole.java:223)
at java.lang.Thread.run(Thread.java:534)
Time to load bundles: 46
FUDForum. Page generated in 0.09193 seconds
