| Pre-Built indexes for Infocenter [message #623864] |
Fri, 29 January 2010 18:44  |
rudraksha Messages: 4 Registered: January 2010 |
Junior Member |
I have a Infocenter instance hosted on our server
http://az84ap99.am.freescale.net/infocenter/index.jsp
When I put the plugin and restart the server and enter any keyword for search the Infocenter performs indexing which is taking a very long time.
Is there any way to provide the infocenter a pre-built indexed file so that it refers to this file rather that doing the indexing. We have soe index.xml files but I dont know what are they for.
I thought they are the pre-built indexed files but the are not , they are used as the index when you type some thing are results are automaticaly are changed at bottom.
May be the pre build indexed file is getting generated in some other place.
Let me know a solution if you have implemented such stuff.
Also let me know if you need any more information.
Help will be rally appreciated :)
FUDForum. Page generated in 0.01965 seconds
