| Exception raised when inserting Exit Connection Point References [message #623719] |
Tue, 12 May 2009 11:16 |
Régent L Archevêque Messages: 33 Registered: May 2010 |
Member |
I am using UML2 Tools SDK 0.9.0M7 (0.9.0.v200905080854) and I get an
Error when I insert an "Exit Connection Point Reference" into a
submachine state (see below the details of the exception). This occurs
after the selection of the <exit point> in the Selection Connection
Point Refernces (there is a typo in the Title) when I click OK. If I
close the diagram editor and re-open it then I can see the added
connection point reference. In previous release, this did not occur.
Thank you
Regent ;-)
Exception Raised
org.eclipse.core.commands.ExecutionException: While executing the
operation, an exception occurred
org.eclipse.core.commands.operations.DefaultOperationHistory .execute(DefaultOperationHistory.java:519)
org.eclipse.gmf.runtime.diagram.ui.parts.DiagramCommandStack .execute(DiagramCommandStack.java:206)
org.eclipse.gmf.runtime.diagram.ui.parts.DiagramCommandStack .execute(DiagramCommandStack.java:169)
org.eclipse.gmf.runtime.diagram.ui.parts.DiagramCommandStack .execute(DiagramCommandStack.java:156)
at org.eclipse.gef.tools.AbstractTool.executeCommand(AbstractTo ol.java:399)
org.eclipse.gef.tools.AbstractTool.executeCurrentCommand(Abs tractTool.java:411)
org.eclipse.uml2.diagram.statemachine.part.CreateConnectionP ointReferenceTool.executeCurrentCommand(CreateConnectionPoin tReferenceTool.java:67)
org.eclipse.gmf.runtime.diagram.ui.tools.CreationTool.perfor mCreation(CreationTool.java:133)
at org.eclipse.gef.tools.CreationTool.handleButtonUp(CreationTo ol.java:178)
at org.eclipse.gef.tools.AbstractTool.mouseUp(AbstractTool.java :1064)
at org.eclipse.gef.EditDomain.mouseUp(EditDomain.java:263)
org.eclipse.gef.ui.parts.DomainEventDispatcher.dispatchMouse Released(DomainEventDispatcher.java:374)
org.eclipse.draw2d.LightweightSystem$EventHandler.mouseUp(Li ghtweightSystem.java:538)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:207)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1176)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3485)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3104)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2405)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 21)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:493)
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:194)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:514)
at org.eclipse.equinox.launcher.Main.run(Main.java:1311)
Caused by: org.eclipse.core.runtime.AssertionFailedException: null
argument:failed to create a view
at org.eclipse.core.runtime.Assert.isNotNull(Assert.java:85)
org.eclipse.gmf.runtime.diagram.ui.commands.CreateCommand.do ExecuteWithResult(CreateCommand.java:99)
org.eclipse.gmf.runtime.emf.commands.core.command.AbstractTr ansactionalCommand.doExecute(AbstractTransactionalCommand.ja va:247)
org.eclipse.emf.workspace.AbstractEMFOperation.execute(Abstr actEMFOperation.java:150)
org.eclipse.gmf.runtime.common.core.command.CompositeCommand .doExecuteWithResult(CompositeCommand.java:403)
org.eclipse.gmf.runtime.common.core.command.AbstractCommand. execute(AbstractCommand.java:135)
org.eclipse.core.commands.operations.DefaultOperationHistory .execute(DefaultOperationHistory.java:511)
.... 37 more
FUDForum. Page generated in 0.01511 seconds
