Home » Eclipse Projects » Eclipse Communications Framework (ECF) » Possible bug in ECF AppGenericServer
Possible bug in ECF AppGenericServer [message #623592] Fri, 30 May 2008 04:45 Go to next message
Syed Sajid Hussain Shah is currently offline Syed Sajid Hussain Shah
Dear sir I am trying to launch an ECF AppGenericServer, for the last whole
weak by using the command
eclipse.exe -console -application org.eclipse.ecf.provider.AppGenericServer
but it gives me the following error.
No service type for event <javax.jmdns.ServiceEvent>
javax.jmdns.ServiceEvent[so
urce= ---- Services -----
---- Types ----
Type:
8.4.a.4.9.a.e.f.f.f.3.9.3.0.2.0.0.0.0.0.0.0.0.0.0.0.0.0.0.
8.e.f.ip6.arpa.:
8.4.A.4.9.A.E.F.F.F.3.9.3.0.2.0.0.0.0.0.0.0.0.0.0.0.0.0.0.8. E.F
ip6.arpa.
Type: _rfb._tcp.local.: _rfb._tcp.local.
Type: _http._tcp.local.: _http._tcp.local.
Type: _afpovertcp._tcp.local.: _afpovertcp._tcp.local.
Type: _services._dns-sd._udp.local.:
l.
Type: _net-assistant._udp.local.: _net-assistant._udp.local.
---- cache ----
record[a,in,fehmarn.local.,3600/3599, address
'132.176.75.108']
record[ptr,in,_services._mdns._udp.local.,3600/3599,_net-ass ista
nt._udp.local.]
record[ptr,in,_services._mdns._udp.local.,3600/3599,8.4.A.4. 9.A.
E.F.F.F.3.9.3.0.2.0.0.0.0.0.0.0.0.0.0.0.0.0.0.8.E.F.ip6.arpa .]
record[ptr,in,_services._mdns._udp.local.,3600/3599,_rfb._tc p.lo
cal.]
record[ptr,in,_services._mdns._udp.local.,3600/3599,_http._t cp.l
ocal.]
record[ptr,in,_services._mdns._udp.local.,3600/3599,_afpover tcp.
_tcp.local.]
record[ptr,in,_services._mdns._udp.local.,3600/3599,_service s._d
ns-sd._udp.local.]
---- Service Collectors ----] name null type
2.0.0.0.0.0.0.0.0.0.0.0.0.0.0.8.E.F.ip6.arpa. info null and JMDNS service
type
8.4.A.4.9.A.E.F.F.F.3.9.3.0.2.0.0.0.0.0.0.0.0.0.0.0.0.0.0.8. E.F.ip6.arpa.
Can you please help me in this regard?
Re: Possible bug in ECF AppGenericServer [message #623593 is a reply to message #623592] Fri, 30 May 2008 05:06 Go to previous messageGo to next message
Markus Kuppe is currently offline Markus Kuppe
> whole weak by using the command
> ---- Types ----
> Type:
> 8.e.f.ip6.arpa.:
> ip6.arpa.
> l.
> ---- cache ----
> '132.176.75.108']
> nt._udp.local.]
> cal.]
> ocal.]
> _tcp.local.]
> ns-sd._udp.local.]
> service type
might be related to this bug [1].
Cheers
Markus
[1] https://bugs.eclipse.org/202774
Re: Possible bug in ECF AppGenericServer [message #623594 is a reply to message #623593] Fri, 30 May 2008 15:21 Go to previous messageGo to next message
Scott Lewis is currently offline Scott Lewis
Syed,
Does this prevent the AppGenericServer from starting, or does it
continue to start and run?
As Markus indicated, this does indeed seem to be a problem with JmDNS
running on ipv6 networks. I will attempt to get the JmDNS folks paying
attention to this bug as possible...but realistically it may take them
some time to address it. Part of the slowdown, I expect, is the
availability of of ipv6 networks for testing/reproing the problem.
Scott
>> ---- Types ----
>> Type:
>> 8.e.f.ip6.arpa.:
>> ip6.arpa.
>> l.
>> ---- cache ----
>> '132.176.75.108']
>> nt._udp.local.]
>> cal.]
>> ocal.]
>> _tcp.local.]
>> ns-sd._udp.local.]
>> service type
> Cheers
> Markus
Re: Possible bug in ECF AppGenericServer [message #623681 is a reply to message #623594] Mon, 02 June 2008 04:51 Go to previous message
Dear ECF Team
As I understand, this is an exception. The AppGenericServer does not run
anymore after this exception comes.
Also it is very very slow to respond
Cheers
Sajid
Scott Lewis wrote:
> Syed,
> Scott
>>> ---- Types ----
>>> Type:
>>> 8.e.f.ip6.arpa.:
>>> ip6.arpa.
>>> l.
>>> ---- cache ----
>>> '132.176.75.108']
>>> nt._udp.local.]
>>> cal.]
>>> ocal.]
>>> _tcp.local.]
>>> ns-sd._udp.local.]
>>> service type
>> Cheers
>> Markus
Previous Topic:Question About Shared Editors
Next Topic:ECF RC3
Current Time: Mon May 20 22:22:14 EDT 2013
Powered by FUDForum. Page generated in 0.01902 seconds
