| standalone html help and resource ids (contextIds) [message #623570] |
Wed, 14 October 2009 11:31  |
Yan Periard Messages: 11 Registered: July 2009 |
Junior Member |
We are looking for a way to find/link to topic in the infocenter without having to use the html filename. We have found the topic parameter but this uses the topic filename. Is there a parameter that we can use to link to a specific topic by using an internal id?
We are producing documentation from a set of DITA topics/maps and would like to add a level of indirection so that even if the filenames are changed the help continues to point to the correct location. For example in DITA the resourceId http://docs.oasis-open.org/dita/v1.1/OS/langspec/langref/res ourceid.html would be our preferred way of doing this.
Is it possible?
We have tried the following, hoping that context help would work in an infocenter, but we must be doing something wrong.
http://localhost:8081/help/index.jsp?contextId=com.ixiasoft. eclipse.product.help.search_view
We are starting the infocenter from a simple java test class using the org.eclipse.help.standalone.Help class, are there options that must be used to enable context help? BTW context help is working fine locally in the full eclipse application.
any help would be appreciated.
thanks.
FUDForum. Page generated in 0.01802 seconds
