Home » Eclipse Projects » Eclipse Communications Framework (ECF) » ECF 2.0M7 update broken?
ECF 2.0M7 update broken? [message #623503] Wed, 07 May 2008 04:39 Go to next message
Joseph Schwarz is currently offline Joseph Schwarz
I installed Eclipse 3.4M7 and ECF 2.0.0v20080504-1400 via "Software
Updates" two days ago. Today, I saw that ECF 2.0M7 (2.0.0v20080506-2244)
was out and I tried to update to it. About 30% of the way through the
update, it failed and I saw a "FileNotFound" exception in the log (excerpt
below).
I'm not sure whether this is a p2 or an ECF problem; can someone advise me
here? Should I submit this as a bug on p2 or on ECF?
Thanks for any help you can give me.
!ENTRY org.eclipse.equinox.p2.engine 4 8 2008-05-07 09:56:16.936
!MESSAGE An error occurred while collecting items to be installed
!SUBENTRY 1 org.eclipse.equinox.p2.artifact.repository 4 0 2008-05-07
09:56:16.936
!MESSAGE Problems downloading artifact:
osgi.bundle,org.eclipse.ecf.ui,2.0.0.v20080506-2244.
!SUBENTRY 2 org.eclipse.ecf.identity 4 0 2008-05-07 09:56:16.936
!MESSAGE Exception connecting to
http://download.eclipse.org/technology/ecf/2.0/3.4/updateSit e/plugins/org.eclipse.ecf.ui_2.0.0.v20080506-2244.jar
!STACK 0
java.io.FileNotFoundException:
sun.net.www.protocol.http.HttpURLConnection.getInputStream(H ttpURLConnection.java:1239)
org.eclipse.ecf.provider.filetransfer.retrieve.UrlConnection RetrieveFileTransfer.openStreams(UrlConnectionRetrieveFileTr ansfer.java:228)
org.eclipse.ecf.provider.filetransfer.retrieve.AbstractRetri eveFileTransfer.sendRetrieveRequest(AbstractRetrieveFileTran sfer.java:639)
org.eclipse.ecf.provider.filetransfer.retrieve.AbstractRetri eveFileTransfer.sendRetrieveRequest(AbstractRetrieveFileTran sfer.java:381)
org.eclipse.ecf.provider.filetransfer.retrieve.MultiProtocol RetrieveAdapter.sendRetrieveRequest(MultiProtocolRetrieveAda pter.java:95)
org.eclipse.equinox.internal.p2.artifact.repository.ECFTrans port.transfer(ECFTransport.java:162)
org.eclipse.equinox.internal.p2.artifact.repository.ECFTrans port.performDownload(ECFTransport.java:120)
org.eclipse.equinox.internal.p2.artifact.repository.ECFTrans port.download(ECFTransport.java:100)
org.eclipse.equinox.internal.p2.artifact.repository.simple.S impleArtifactRepository.downloadArtifact(SimpleArtifactRepos itory.java:409)
org.eclipse.equinox.internal.p2.artifact.repository.simple.S impleArtifactRepository.getArtifact(SimpleArtifactRepository .java:452)
org.eclipse.equinox.internal.p2.artifact.repository.MirrorRe quest.transfer(MirrorRequest.java:132)
org.eclipse.equinox.internal.p2.artifact.repository.MirrorRe quest.perform(MirrorRequest.java:109)
org.eclipse.equinox.internal.p2.artifact.repository.simple.S impleArtifactRepository.getArtifact(SimpleArtifactRepository .java:441)
org.eclipse.equinox.internal.p2.artifact.repository.simple.D ownloadJob.run(DownloadJob.java:64)
!STACK 0
Re: ECF 2.0M7 update broken? [message #623504 is a reply to message #623503] Wed, 07 May 2008 04:47 Go to previous messageGo to next message
Markus Kuppe is currently offline Markus Kuppe
> (excerpt below).
> me here? Should I submit this as a bug on p2 or on ECF?
Just a hunch... ECF M7 has just been announced and it might very well
be, that the update site isn't completely deployed yet?
Cheers
Markus
Re: ECF 2.0M7 update broken? [message #623505 is a reply to message #623504] Wed, 07 May 2008 08:17 Go to previous messageGo to next message
I took your advice and waited a couple of hours. When I tried again to
update, I got a different error this time (see below). I finally
reinstalled Eclipse M7 from scratch and installed ECF 2.0M7 from the
update site successfully. I still suspect that there's something wrong
with the update process, either on the p2 side or the ECF side.
The error in the log was:
!SESSION 2008-05-07 14:06:50.839
-----------------------------------------------eclipse.build Id=I20080502-0100
java.version=1.6.0_04
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US
Command-line arguments: -os linux -ws gtk -arch x86
!ENTRY org.eclipse.equinox.p2.engine 4 8 2008-05-07 14:07:21.409
!MESSAGE An error occurred while uninstalling
!SUBENTRY 1 org.eclipse.equinox.p2.touchpoint.eclipse 4 0 2008-05-07
14:07:21.409
!MESSAGE A feature with the specified id was not found.
!ENTRY org.eclipse.equinox.p2.engine 4 8 2008-05-07 14:07:43.389
14:07:43.389
Re: ECF 2.0M7 update broken? [message #623506 is a reply to message #623505] Wed, 07 May 2008 11:51 Go to previous messageGo to next message
Scott Lewis is currently offline Scott Lewis
Hi Joseph,
This obviously looks like an uninstall problem with p2 (perhaps caused
by the failed initial install by ECF...but I'm speculating). Could you
create a bug report for p2 here:
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Equinox
Scott
> 14:07:21.409
> 14:07:43.389
Re: ECF 2.0M7 update broken? [message #623508 is a reply to message #623506] Thu, 08 May 2008 03:32 Go to previous message
Hi Scott,
Thanks for the advice. I've submitted the bug report, and you can follow
progress at https://bugs.eclipse.org/bugs/show_bug.cgi?id=231049
Joe
Previous Topic:Question with jslp library included in ECF jslp provider
Next Topic:Issue with using ECF in RCP
Current Time: Tue May 21 04:01:51 EDT 2013
Powered by FUDForum. Page generated in 0.10691 seconds
