| ECF 2.0M7 update broken? [message #623503] |
Wed, 07 May 2008 04:39  |
Joseph Schwarz Messages: 6 Registered: July 2009 |
Junior Member |
I installed Eclipse 3.4M7 and ECF 2.0.0v20080504-1400 via "Software
Updates" two days ago. Today, I saw that ECF 2.0M7 (2.0.0v20080506-2244)
was out and I tried to update to it. About 30% of the way through the
update, it failed and I saw a "FileNotFound" exception in the log (excerpt
below).
I'm not sure whether this is a p2 or an ECF problem; can someone advise me
here? Should I submit this as a bug on p2 or on ECF?
Thanks for any help you can give me.
!ENTRY org.eclipse.equinox.p2.engine 4 8 2008-05-07 09:56:16.936
!MESSAGE An error occurred while collecting items to be installed
!SUBENTRY 1 org.eclipse.equinox.p2.artifact.repository 4 0 2008-05-07
09:56:16.936
!MESSAGE Problems downloading artifact:
osgi.bundle,org.eclipse.ecf.ui,2.0.0.v20080506-2244.
!SUBENTRY 2 org.eclipse.ecf.identity 4 0 2008-05-07 09:56:16.936
!MESSAGE Exception connecting to
http://download.eclipse.org/technology/ecf/2.0/3.4/updateSit e/plugins/org.eclipse.ecf.ui_2.0.0.v20080506-2244.jar
!STACK 0
java.io.FileNotFoundException:
sun.net.www.protocol.http.HttpURLConnection.getInputStream(H ttpURLConnection.java:1239)
org.eclipse.ecf.provider.filetransfer.retrieve.UrlConnection RetrieveFileTransfer.openStreams(UrlConnectionRetrieveFileTr ansfer.java:228)
org.eclipse.ecf.provider.filetransfer.retrieve.AbstractRetri eveFileTransfer.sendRetrieveRequest(AbstractRetrieveFileTran sfer.java:639)
org.eclipse.ecf.provider.filetransfer.retrieve.AbstractRetri eveFileTransfer.sendRetrieveRequest(AbstractRetrieveFileTran sfer.java:381)
org.eclipse.ecf.provider.filetransfer.retrieve.MultiProtocol RetrieveAdapter.sendRetrieveRequest(MultiProtocolRetrieveAda pter.java:95)
org.eclipse.equinox.internal.p2.artifact.repository.ECFTrans port.transfer(ECFTransport.java:162)
org.eclipse.equinox.internal.p2.artifact.repository.ECFTrans port.performDownload(ECFTransport.java:120)
org.eclipse.equinox.internal.p2.artifact.repository.ECFTrans port.download(ECFTransport.java:100)
org.eclipse.equinox.internal.p2.artifact.repository.simple.S impleArtifactRepository.downloadArtifact(SimpleArtifactRepos itory.java:409)
org.eclipse.equinox.internal.p2.artifact.repository.simple.S impleArtifactRepository.getArtifact(SimpleArtifactRepository .java:452)
org.eclipse.equinox.internal.p2.artifact.repository.MirrorRe quest.transfer(MirrorRequest.java:132)
org.eclipse.equinox.internal.p2.artifact.repository.MirrorRe quest.perform(MirrorRequest.java:109)
org.eclipse.equinox.internal.p2.artifact.repository.simple.S impleArtifactRepository.getArtifact(SimpleArtifactRepository .java:441)
org.eclipse.equinox.internal.p2.artifact.repository.simple.D ownloadJob.run(DownloadJob.java:64)
!STACK 0
FUDForum. Page generated in 0.01719 seconds
