| ebedded emftext editor [message #623060] |
Wed, 14 July 2010 21:52  |
mxm1512 Messages: 3 Registered: July 2010 |
Junior Member |
Hi all,
is it possible to use emftext editor as propertysheet celleditor.
I defined a constraint language, and i want edit my constraints in a property view on the same way like a multiline text editor
mxm
| Re: ebedded emftext editor [message #623061 is a reply to message #623060] |
Wed, 14 July 2010 22:22   |
Ed Merks Messages: 24530 Registered: July 2009 |
--------------040702020607080301020001
Content-Type: text/plain; charset=UTF-8; format=flowed
Mxm,
I'm not sure what you're referring to with emftext editor, but maybe
this recipe helps:
3.1 Recipe: Create your own property editor in a generated
application
< http://wiki.eclipse.org/EMF/Recipes#Recipe:_Create_your_own_ property_editor_in_a_generated_application>
mxm1512 wrote:
> Hi all,
> Regards, mxm
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
Mxm,<br>
<br>
this recipe helps:<br>
<blockquote><a
href=" http://wiki.eclipse.org/EMF/Recipes#Recipe:_Create_your_own_ property_editor_in_a_generated_application"><span
class="tocnumber">3.1</span> <span class="toctext">Recipe: Create
your own property editor in a generated application</span></a><br>
<br>
</blockquote>
mxm1512 wrote:
<blockquote cite="mid:i1lpk1$k9t$1@build.eclipse.org" type="cite">Hi
all,
<br>
<br>
<br>
<br>
<br>
Regards, mxm
<br>
</blockquote>
</body>
</html>
--------------040702020607080301020001--
| Re: ebedded emftext editor [message #623062 is a reply to message #623060] |
Thu, 15 July 2010 02:32  |
Jan Reimann Messages: 65 Registered: July 2009 |
Member |
Hi mxm,
for questions about EMFText you'd better use the mailing list. Have a
look at http://www.emftext.org/index.php/EMFText_Contact
But I assume this is a general question whether it is possible to use a
regular editor as a view or cell editor. Maybe the pde group is another
possibility to ask that?
best regards,
Jan
mxm1512 wrote:
> Hi all,
> Regards, mxm.
FUDForum. Page generated in 0.04456 seconds
